Mike T
May 24 2003, 12:46 AM
I'm doing the engine compartment in my Green '75 autocrosser in preparation for the V8 swap.
There is no rust to contend with but currently it's 28 year old faded green with a quicky black spraybomb job. Need some ideas. I thought of just painting it green to match the body. Or I sort of like the look of Hammerite. I am open minded on the matter.
Mike T
Brad Roberts
May 24 2003, 12:51 AM
Go green. Make it easy to see when working on the car. Dont use the trunk texture crap.. ir never really dries.
B
need4speed
May 24 2003, 02:03 PM
I would go with white - for the same reason - makes it easier to see what you're working on, plus, easier to spot leaks, etc.
joea9146
May 24 2003, 02:31 PM
I like to keep the same color as the car
watsonrx13
May 24 2003, 03:22 PM
Green, definately green...
Andyrew
May 24 2003, 06:52 PM
You should be able to see things just about as clearly in the green as you do white, plus lotsa dirt/grease isnt as noticable.. Good luck!
Qarl
May 24 2003, 09:19 PM
Rust colored. That way you won't notice the rust.
Zeke
May 24 2003, 10:29 PM
Candy apple tagerine metal flake.
Frankly, I'll vote for green as well. Not my favorite color, but matching the exterior is always a winner. I don't see a problem with the black either. I've seen a few engines with the tin painted colors to set the engine off from the black.
BTW, you can see the oil, grease and dirt on any surface. Don't kid yourselves.
J P Stein
May 24 2003, 10:33 PM
I like light colors....white or light gray. Yours is not exactly a CW car
Lawrence
May 25 2003, 07:46 AM
White, silver, yellow?
Anything to get more light in the bay.
-Rusty
Gint
May 25 2003, 08:36 AM
Tangerine! Oh wait, that's my car. Seriously, I thought about painting my engine compartment white or grey. In the end though I think the orange will be bright enough (once all of the years of caked on grease is gone).
I would just paint it green to match the car color.
Lawrence
May 25 2003, 10:50 AM
Even green will be bright, once he ditches the engine sound pad and cleans all the glue up.
-Rusty
Mike T
May 25 2003, 07:30 PM
@#%$&*! glue!
What the hell is that made out of? Finally ended up sanding to get rid of it. I keep thinking of how nice it will look all shiney green.
Pass the sandpaper please...
Mike T
Aaron Cox
May 25 2003, 07:33 PM
id go with car color....unless you went chamelion
