QUOTE(Java2570 @ Sep 28 2013, 10:14 AM)
Len - I believe that taking a resistance reading you should get approx. 14 ohms....
thats + lead to AAR connector and - grounding on case of AAR. If you have a problem in the wire you should have a higher ohm reading. I know I fritzed out my old one in a similar way and testing it got a reading of about 36 ohms. Plus, my reading varied quite a lot when I moved the wire around during testing. You should also verify that you are getting 12 V from the wiring harness....
I think what happened to me was that the +12 going to the AAR went right to ground via the case.
Should there be continuity between the + lead and the case?
(reveal - I know nothing about electronics)
