QUOTE(Jake Raby @ Sep 28 2013, 01:31 PM)
Retarding timing elevates EGT and will build head temps too.
If your OT is too high in the cool weather our region has been experiencing lately, you definitely have something contributing to it. A 2056 seldom needs more than a stock oil cooler, even in hot climates.
Sounds like an underlying issue that you hope to fix with a band aid.
Jake I hope to not take that approach. While we all think we have thought of everything there is always something we can miss. Thanks for the reminder to check the simple stuff so here is what I have done.
I have verified that the flaps are in the correct position to direct air flow through the cooler.
I have verified the temp with an external thermometer, when the gauge is moving toward red is 240 F or higher.
Click to view attachmentThis corresponds closely to the range I am using for comparison.
Click to view attachmentSo the heat problem seems real and verifiable.
This is a new build 2056 with new jugs, pistons, and valve job with new guides. 2.0 head vents are still in place and routed to external vent. Oil cooler seals replaced and there is no blockage of the cooler or air paths. Verified with bore scope.
Valves seem to be adjusted. Checked twice.
Running weber 44s, 28, vents, 60 idle jets, 1.45 mains, 175 air correction jets, and F-11 emulsion tubes.
Have SVDA dizzy and 27 of advance at 3000 rpm no vac. New stock coil. Have slight pinging on full load as the engine gets warmer. Not present when cool.
Plugs show a good burn not lean. Plugs set to stock gap 28 to 30 I think.
All engine tin is in place. Impeller is turning.
So there is nothing that leaps out at me as a problem. That kind of goes without saying.
The heat seems to build up slowly on longer drives at interstate speeds. To me this looks like a heat dissipation problem. But I may be missing what is causing the heat.
Thoughts?
