frank lamanski
Sep 28 2013, 06:13 PM
New to all this air cooled stuff . Put had my 914 for about a year .first leak is at push rod tube .the tube is loose and leaking .next leak is were the oil filter bracket bolts to motor thier are two nuts that hold this on can i get it off .looks like oil cooler is in the way
Mblizzard
Sep 28 2013, 08:57 PM
The oil tubes can be dealt with by replacing the seals. Not fun but doable with out a major effort.
When you say the oil filter "bracket" do you mean the part that the filter screws on to that is held on to the case by bolts? I may be wrong but I thought that this was a part that was either pretty easy to remove or that it could only be removed if a number of other parts are removed. But I have not seen one leak from there. May just be something I have not seen but I would check the oil sending unit on top of the case by the dizzy and the oil cooler seals to be sure it is not oil coming from above.
frank lamanski
Sep 29 2013, 06:00 PM
Yes that is what iam talking about .can see oil leaking right were it seal to the block
Mike Bellis
Sep 29 2013, 06:15 PM
frank lamanski
Sep 29 2013, 09:36 PM
QUOTE(kg6dxn @ Sep 29 2013, 05:15 PM)
thank you
Dave_Darling
Sep 30 2013, 08:52 AM
If a pushrod tube is loose, the spring that holds it in place is probably not in the right spot. The spring is the "bent wire" piece that goes on the underside of the rocker arm holders. The lower parts are supposed to go on the shoulders of the tubes, not stick down the tubes. You can pull them with a pick--I use a small L-shaped Allen wrench--until they click onto the shoulders of the tube.
Getting at the oil filter console nuts is a pain, but it is doable. It's easier without the filter in place, and also without the heater stuff in place. If your car has the 75-76 exhaust, you may need to remove the exhaust as well. Then use "stubby" wrenches, plus 1/4" drive sockets, extensions, U-joints, "wobble" extensions, and any other tricks you have to get the socket onto the nut.
--DD
frank lamanski
Sep 30 2013, 12:35 PM
Thank you for the support will give it a try
Dave_Darling
Sep 30 2013, 03:26 PM
QUOTE(Dave_Darling @ Sep 30 2013, 07:52 AM)
By "them" I mean the lower parts of the wire, not the pushrods or the tubes. Just realized my response may not have been as clear as I meant it to be.
--DD
TheCabinetmaker
Sep 30 2013, 06:52 PM
There was a thread a few weeks ago regarding the filter mount. It involved removing the oil cooler nuts and sliding it forward as far as it will go then you can access the top nut on the mount. I had an oil and filter change on the lift today and took a good look at the area with the filter off. It looks very doable. I'll find out next week cause I have another car that is leaking there. Mine!
frank lamanski
Oct 1 2013, 07:34 AM
QUOTE(The Cabinetmaker @ Sep 30 2013, 05:52 PM)
Thank you for all the help. Got it off yesterday after about 3 hour no gasket on it .what do you think about moving oil filter .Do thay make a kit to move filter up top ?
frank lamanski
Oct 1 2013, 07:35 AM
QUOTE(frank lamanski @ Oct 1 2013, 06:34 AM)
Cap'n Krusty
Oct 1 2013, 08:04 AM
If that essential gasket was missing, I would be inclined to view the condition of the rest of the engine with suspicion.
The Cap'n
stugray
Oct 1 2013, 08:20 AM
Unless you use the Loctite "Gasket eliminator" like what Jake provides in his sealant kit.
It works perfectly for that interface while regular silicone would not do well alone for that application.
