Mueller
Dec 16 2004, 10:04 PM
for my 2316 it seems that the stock plenum might be reaching it's limits as far as volume goes.....so, I either fabricate a larger common plenum, or go with individual throttle bodies such as TWM or
Jenvey*single plenum would be easiest, but the individual throttle bodies look better
has anyone switched from one to the other on the same motor with everything else being the same???
*Jake Raby is
the U.S. distributor of these....
lapuwali
Dec 16 2004, 10:18 PM
Biggest problem with IR throttles is getting a good MAP signal for the EFI. You need to fab up a plenum just for the MAP signal. You never need to balance a single throttle body, either. No linkage worries. Fabbing up a bigger plenum that used the stock runners shouldn't be too big a deal. Use a bigger throttle body off some other EFI car.
ottox914
Here is another place to check for FI throttle bodies, manifolds, and injectors:
http://redlineweber.com/Redline1.htmI have been interested in the same question for a while- general answers I get are that the longer runners/larger single plenum can be designed to boost low/mid range torque, while the I/R throttle bodies will help the top end. Might be a "package" sort of decision, thinking about valve sizes, cam, redline, etc. Jake had a thread awhile back about testing intake velocity stacks, and found 2.5" to be the best overall size, so if you go I/R this might be worth keeping in mind.
As far as real world experience, got none to share, only opinions at this time. I'm not the smartest nut on the workbench, but am working my way thru "Scientific Design of exhaust and intake systems" third edition, by smith and morrison. It'll take a while for it to all sink in, but interesting none the less.
Bleyseng
Dec 16 2004, 10:41 PM
QUOTE(Mueller @ Dec 16 2004, 08:04 PM)
Based on what? Have you done the math? Brad ever built something like that and it didn't work??
DaveHunt's 2270 is supposed to be running tonight and he should get it tuned soon sooo we'll all know if a 2.0l setup can work well.
Charles from L/N told it should work but maybe suffer alittle at high rpms. So, how high you gonna rev this thing??
Geoff (looks like I am heading down this slippery slope also)
914werke
Dec 16 2004, 10:56 PM
Im not smart enough to follow this ...
Why would the collection of intake air in a larger common cavity enhance mid & torq as compared individualm properly sized TB's?
Bleyseng
Dec 16 2004, 11:01 PM
air velocity I think. Under lite vacuum at cruising the plenum is a large supply of air already past the TB. Duals is great for WOT.
Thats why the throttle response it so great with a Djet set up vs Dual carbs.
or I am talking out my ass...........
eeyore
Dec 16 2004, 11:10 PM
The general gist is short intake runners for high RPM, long runners for low RPM. It isn't just the piston downstroke that moves air into the cylinders, it is the masses of air moving through the engine as well. At low RPM, with low piston velocity and intake pulses stretched out, lengthening an intake runner creates a reservior of high(er) momentum air to help fill the cylinder.
I think that valve overlap is another thing that assists in cylinder filling, where both valves are open at the same time so that the outgoing air charge is creating a vacuum on the incoming charge.
Dual carbs with IRs probably have poor low RPM response due to low intake velocity, hence poor fuel atomization. (Now I'm talking out of my ass too)
Dual-length runners systems are what made the Corvette ZR-1 and the SHO Taurus great (if it wasn't sales hype)
Mueller
Dec 16 2004, 11:55 PM
Geoff,
Based on another thread in which Jake mentions it on Dave’s motor, mine will be larger and if his is already on the brink, then mine would reach the limit even sooner
Just 'cause Dave’s car runs, it does not mean the plenum is sufficient in volume, he won't know for sure until he cranks up the RPMs.....one way to know whether it works fine is how well the car responds at WOT, too much vac. at WOT and it could indicate too small of a plenum (the throttle body could do this as well, but I know he has a larger throttle body to help)
Bleyseng
Dec 17 2004, 12:17 AM
The difference between a 2270 and a 2316 isn't that much is it? You can always add a bigger TB onto the 2.0l plenum for better WOT flow, say a 55mm one. Just ream out the hole some.
I spoke with Jake and Charles the other night and they feel they can come up with a cam that will work with my new setup (103x71 using Nikkies and Djet intake, 45mm TB)
ottox914
Dec 17 2004, 08:25 AM
My very basic understanding of plenum and runners VS throttle bodies: when the intake valve closes, the incoming air charge is still on its way, hits the closed valve, and bounces backwards thru the intake runner and into the plenum. By doing the math (not my strong suit) you could take in to account the speed of the "bounce back", the volume and shape of the runner, size of the plenum, and calculate lengths for runners, and capasity of plenum, such that when the incoming air charge bounces off the plenum, and rushes back down the intake runner, that it gets back to the valve as it is opening again, resulting in better cylinder filling, sort of a "super chargeing" of the intake charge. Down side to this is that is is pretty rpm dependent, based on length of runners and timing of valves opening/closing, hence some cars w/variable length "tuned" intake runners. The individual throttle bodies, if run open topped, have nothing for the charge to bounce back off of, but do offer lots of air flow and a more direct path at higher rpms. If they are run w/air cleaners, again, the overall length of the intake, from the top of the air cleaner (or thorttle plate?) to the valve is likely to be less than the stock T4 system, and the bounce back effect happens faster, and therefore provided more benefit at higher rpms, when the valves are open/closeing faster.
Thats all I think I know, if someone knows more feel free to correct me.
Jake Raby
Dec 17 2004, 08:54 AM
Bleyseng,
I have never had ANY engine that I could not design a proper cam for! The D jet that you are using is much more tricky and that cam will have split centers, split lift and split duration, so it won't be cheap! I do have 4 different masters we can work with and some data from Djet tests in the past to compare. Using the Djet SAFELY will sacrifice duration which will boost vacuum (atleast on the intake side) this will cost you drastic power of the potential of the combination using something else_Kit Carlson or Carbs... But If you really wanna use it, go for it- but its uncharted territory!
Getting a proper vac signal for the IR runners is easy. I have already found in the Kit Carlson testing the size of the vac ports needed as well as the hose and small collector that works best as well. One of the test engines that made the best power was an IR set up that actually idled and fired up with low speed operation better than the plenum based version in my 912E.
BUT you need the correct cam designed to make this easier- Yet again no problem because I'm a cam specialist on these suckers! Its just come from trial and error!
All the guessing and planning in the world and trying your heart out to get it perfect ain't gonna cut it! Unless you use a 100% proven arrangement that has all the bugs worked out and has EVERY part that was used in that arrangement installed- You can make a goof....
Don't be afraid of making goofs- If you are don't try it and pay someone else that is. Its impossible to build it perfect! It can ALWAYS be better! Take it from me, the guy that has torn a particular engine down 18 times making nothing but a cam change to find out the heads were the limiting factor because the ports and valves were too big! The issue looked cam related, but it wasn't.
Build it, drive it, and if you don't like it tear down and change it- OR get a full set up 100% designed to work and you better not complain about the friggin price, because all guesswork is removed and thats worth DOUBLE the cost alone!
BTW, I'm the only US based dealer for Jenvey TBs. I have exclusive rights to thier goodies and they are being added to our line up as we speak.
Take this seriously guys, but understand its never gonna be perfect-
Bleyseng
Dec 17 2004, 09:02 AM
Jake, I am going with the Megasquirt setup but retain the djet intake set up. If it doesnt work, well I have a set of Dells sitting on the shelf.
If Dave Hunt can't get his to run right I will be changing my direction.
Geoff
Jake Raby
Dec 17 2004, 09:11 AM
I'm sure he can make it run right, but the question is will the engines VE have to be sacrificed to do so???? If it needs weird VE numbers to be drivable and stay cool it will suffer in the performance arena.
That VE table will tell the tale.
The plenum that Charles and I have been working on will be sized for 2250-2320CC engines specifically.
Bleyseng
Dec 17 2004, 09:15 AM
Ok, 'bout how much more Volume do you think it will take.(so I can imagine this in my head). Double? 50%? 60mm TB?
Geoff
Jake Raby
Dec 17 2004, 09:41 AM
Mueller
Dec 17 2004, 11:27 AM
I like that additude
Guess I'll be going the IR route....like you said, if it does not suit me, replace it with something else till it does
jwalters
Dec 17 2004, 11:38 AM
QUOTE(rdauenhauer @ Dec 16 2004, 08:56 PM)
This si the same technology all the japanese bike makers use to squeeze every last iota of power from the tiny engines...point:
Testing has showed and confirmed that having the largest Airbox possible slows down the intake velocity and turns it into pressure-----
Further testing has shown and confirmed that the use of a decent sized airbox coupled with a large plenum has the same effect--
On these engines as well as any other high rpm / high power engine the speed of the air being "sucked" into the carbs are approaching or exceeding the speed of sound--this is not good--high velocity means low pressure, think of it as a carb venturi--by being in the transonic range ( just prior to going supersonic) and pushing thru S/S, negative pressure waves develope which can in the right instance actually stop and restart the flow of air up to 100k times per second.
Which gives very poor performance and causes aircraft jet engines to " flame out" i.e.-...not run at all.
Too much velocity is bad juju-----
Jake Raby
Dec 17 2004, 12:03 PM
The only true test is in the driver's seat....
100% of what I have developed has been proven this way...
Most of what I have was developed was done before I ever owned a dyno.... Including the camshafts- Thats why they are so damn effective in the driver's seat..
Dec 17 2004, 03:26 PM
single plenum ...
use a 3.2 upper intake and cut off 2 of the runners.
the dia. of the runners is a bit bigger than the 2.0 runners, perfect for anything from 2056 to 2316 (according to my pre-school math).
the 3.2 plenum has much more volume over the 2.0 plenum, which is gud.
also, the runners are much longer, promoting low/mid range torque.
all you need to do is find a set of short dual carb runners and mate the 3.2 intake to them. they're only about 3 mm off.
i went through this whole setup for my 2056, did all the math/research.
just haven't deceided yet if i'm actually going to use it ...
Andy
nebreitling
Dec 17 2004, 03:51 PM
that's a brilliant idea, andy.
Bleyseng
Dec 17 2004, 05:36 PM
Got a pic of what you are talking about?
Dec 17 2004, 05:57 PM
QUOTE(Bleyseng @ Dec 17 2004, 03:36 PM)
yes.
take a 3.2L upper intake with TB and cut it along the green lines in Pic 1.
take off the 2 front runners and weld the plenum shut.
the mounting position of the remaining runners (yellow arrows in Pic 2) alomst perfectly mate on a dual carb intake (yellow arrows in Pic 3).
they're only a few mm off on each side, so it would be easy to make a small adapter to mate them together.
you can use the 3.2 TB, Air Filter, the fuel rails and injectors and just run a MS Brain for the Injection ...
Pic 1:
Pic 2:
Pic 3:
Jeroen
Dec 17 2004, 10:16 PM
Mike, do a search on the pelican taildraggers forum
Some guys there are modifying motorcycle throttle bodies (which can be bought cheap)
Mueller
Dec 17 2004, 11:27 PM
QUOTE(Jeroen @ Dec 17 2004, 09:16 PM)
thanks...read 'em all and now I'm on eBay
Qarl
Dec 17 2004, 11:40 PM
Dec 18 2004, 02:33 AM
QUOTE(Mueller @ Dec 17 2004, 09:27 PM)
trust me, you want a single TB ...
Andy
Brett W
Dec 18 2004, 08:07 AM
The common plenum system will make more power than an IR manifold. The IR will allow instant throttle response, therefore making them a much better choice for a situation where rapid and frequent throttle position changes occur.
While I was at work last night, I was thinking about coming up with a couple of prototype Common Plenum manifolds. I was trying to decide what throttle bodies and fuel injectors to set them up with. The Djet stuff in my opinon is not a good choice for fuel management, but Kit Carlson might be up for the task.
What kind of interst would I see. Since I don't have a running injected car, and am not planning on building one anytime soon, I need someone to do some testing. Jake, got anything running Kit Carlson with an engine with more capacity, 2270+.? Here is the problem. IT would only work for a teener, because anyone running any kind of Upright cooling system would not be able to run this. Don't think I want to try and design one for an upright motor.
Mueller
Dec 18 2004, 01:31 PM
QUOTE(SirAndy @ Dec 18 2004, 01:33 AM)
Andy
why?
??some of the new BMW's use what appears to be a combination of both, individual throttle bodies just a few inches away from the intake ports, but all of the t/b share a common plenum for the air?
Brett,
I think the best choice for the throttle body would be something from a newer car that has aftermarket support for....I've noticed on eBay, a bunch of Ford Mustang and Focus throttle bodies, both stock and aftermarket such as BBK
Now about the placement of the throttle body if going with a plenum design???
cross off how the 1.7/1.8s are mounted......the 2.0 seems like it would be ideal for even flow, but it sure as hell looks goofy with the t/b just sitting up on top.....having the intake on the underside of the plenum similar to 928s (and even some Cosworth Indy motors) is an option, but you have to worry about clearance between the motor and the t/b...also there might be an issue with heat and also the overall height of the plenum would have to be higher for the t/b and aircleaner/ducting
now we go back to the intake that Andy posted, do we want 2 seperate plenums connected together with the t/b in the middle or make one single plenum with the t/b mounted to it (top like 2.0 or front, similar to a newer GM V8)??
Aaron Cox
Dec 18 2004, 01:42 PM
heres a wild thought....use carb manifolds.... weld injector bungs on them.... make a common air box that has a throttlebody on it and connect it to the two carb manifolds
TimT
Dec 18 2004, 02:09 PM
Mike the GT3RS we just tore down has a big box plenum, that sits on individual throttle bodies.
The air intake is tuned with different restrictors that are plaed at the air inlet for the plenum...
Ill shoot some pics. its all carbon fiber and say Porsche Motorsports on it
Mueller
Dec 18 2004, 02:17 PM
QUOTE(Aaron Cox @ Dec 18 2004, 12:42 PM)
that is sorta what Andy posted...the question(s) is how to make the plenum and of what design?
here is my 1st grade type sketches
Mueller
Dec 18 2004, 02:21 PM
QUOTE(TimT @ Dec 18 2004, 01:09 PM)
interesting....how much difference in area do the restrictors have between each other??
Aaron Cox
Dec 18 2004, 02:24 PM
beautiful drawings
pony up for the jenveys and be done with it
Bleyseng
Dec 18 2004, 03:25 PM
Aaron, I was thinking along those lines last nights as I have a set of carb manifolds on the shelf. Just need to get some tube bent, weld on some flanges and bolt that to the manifolds. The plenum could be anything and weld on a TB. The sizing is the key as how big should stuff be?? The 3.2 looks way too big! I read that the runners should be about 10% larger than the intake valve or velocity suffers.
Geoff
Aaron Cox
Dec 18 2004, 03:26 PM
QUOTE(Bleyseng @ Dec 18 2004, 02:25 PM)
Geoff
cool...im not the only crazy one then
Dec 18 2004, 04:32 PM
QUOTE(Bleyseng @ Dec 18 2004, 01:25 PM)
actually, each individual runner on the 3.2 is only slightly larger than a stock 2.0 runner.
they are the *perfect* size for a 2.1 - 2.3 engine.
in fact, there is a formula that porsche used on all their aircooled FI engines.
using that formula and the displacement of your engine (per cylinder) you can calculate the dia. of a individual runner. (and vice versa) ...
the one thing that is much larger is the volume of the plenum, which is gud ...
Andy
Mueller
Dec 18 2004, 05:09 PM
the 3.2 upper might work, my issue with it is that's going to be ugly
Andy, any thought on the single t/b plenum verses a single plenum with multiple t/bs such as the car Tim mentioned?
Dec 18 2004, 05:25 PM
QUOTE(Mueller @ Dec 18 2004, 03:09 PM)
i believe that as long as you have a single plenum to draw air from (all cylinders share the plenum and therefore are connected), both versions should produce good results.
the multiply TB/one common plenum setup will probably give you faster throttle response but then you have to deal with syncronizing 4 TBs ...
as far as *ugly* goes, we all know that beauty is in the eye of the beholder ...
Andy
Aaron Cox
Dec 18 2004, 05:34 PM
QUOTE(SirAndy @ Dec 18 2004, 04:25 PM)
Andy
beauty is in the eye of the beer holder
Mueller
Dec 18 2004, 05:59 PM
hmmmmm, I wonder if a setup like this would make slide-valve throttle bodies work better thru out the entire rpm range????
RD Evans
Dec 18 2004, 06:32 PM
Here is a link to a custom made manifold that might work with our motors?
SDS-FI Manifold
Mueller
Dec 18 2004, 06:39 PM
thanks for the link...nice and simple manifold....i'm thinking with our motors we'd want to add some joints to the setup for expansion.....
Bleyseng
Dec 18 2004, 06:49 PM
Hmm, I thought the intake valves on a 3.2l are 49mm which are much bigger than 42mm stocker. Could always upgrade to 44mm valves....
I trip to a junkyard is in order to look for parts...
Andy, what size does the manifold drop down to at the head flange?
Geoff
TimT
Dec 18 2004, 06:54 PM
This guy makes a nifty throttle alternative "barrel throttles" like slide valves only they rotate.
Jon MilledgeI saw one of the 944s' equiped with this, car was wicked fast...
Mueller
Dec 18 2004, 07:28 PM
pretty damn slick Tim........much easier to seal the "barrels" than a slide...damn professional looking, cannot wait to see what the 911/914/6 version looks like
DNHunt
Dec 18 2004, 07:50 PM
I can't offer much except that about the only thing working well on the new engine right now is the MAP sensor. The old 2.0l with the same sensor and same single throttle body had about 45 kPa of vacuum at 1000 rpm. The 2270 is around 65 kPa. Jake was kidding about a vacuum signature. This thing wants air. I suspect I'll need more throttle body and maybe more plenum.
Anybody thought of a riser on the stock plenum with about a 65 mm throttle body. Easy to make, cheap. You could probably add a couple hundred cc's without too much problem. On the down side you get a shaped column of air aimed at the flat bottom of the plenum you get another gasket and you have to open the top of the plenum up. Also, you loose that nice big air box before the butterfly.
Dave
Air_Cooled_Nut
Dec 18 2004, 08:29 PM
QUOTE(SirAndy @ Dec 18 2004, 02:32 PM)
Andy
Post the formula! Post the formula! Post the...did someone say beer?
Jeroen
Dec 18 2004, 08:47 PM
IIRC slide valves only work better at WOT, when there is no restriction to the inlet path
Dec 18 2004, 09:45 PM
QUOTE(Bleyseng @ Dec 18 2004, 04:49 PM)
40mm at the flange compared to 36mm on the stock 2.0L runners ...
Andy
Bleyseng
Dec 18 2004, 11:04 PM
hmmm, that is damn close then. Someone here must know the ratios....
