The owner just sent me this list to add
The car should have the following installed:
8/24/2003 914 180 lb. Autocross Springs, pair - pelican $105.00
8/24/2003 Ball Cup Shift Bushing at base of shift lever, Rear Ball Cup Bushing 914 (1973-76) pelican $6.45
8/24/2003 Shift Coupler Dowel Pin pelican $2.50
8/24/2003 Rear Shift Rod Bushing, 914 (1973-76) pelican $9.90
8/24/2003 Firewall Shift Bushing, 914 (1973-76) pelican $9.95
8/28/2003 914 Battery Tray and Support Kit pelican $48.00
8/28/2003 Right Side Heater Hose pelican $14.95
8/28/2003 Heater Hose, Engine Compartment, Left Side pelican $9.95
8/28/2003 914 Interior Light Assembly (VW style). Requires 1 bulb, 12V, 10W Part J-631-106-90 pelican $9.95
8/28/2003 Clothes Hook Cover (sold per each), 914, 911 pelican $3.20
pelican $9.53
8/28/2003 Inner Door Seal, 1970-76 914 Left pelican $47.50
8/28/2003 914 Threshold Plate, Inner pelican $45.90
9/7/2003 Acid Battery Tray Mat, 8 inch x 12 inch $5.50
9/7/2003 Brake line hose clamp, each (4 of them) pelican $10.00
9/7/2003 911/914 Master Cylinder brake line to reservoir hose, blue braided hose, sold per foot, cut to size (8 feet) pelican $66.00
10/5/2003 tail light seals (ebay) ebay $12.00
10/20/2003 Pedal Sets - Race-Set w/Dead pedal rennline $198.42
11/1/2003 2 914 Koni Shock Absorbers (FRONT, 8641- 1077 Sport) Paragon $330.00
11/1/2003 2 914 Koni Shock Absorbers (REAR, 8641- 1050 Sport) Paragon $272.00
11/1/2003 914RS050/070 (RS-070 Rack Spacer Kit, 914 1973-76) Paragon $14.00
11/1/2003 914.70.34.95.00 914 Koni Competition Bump Rubber REAR Paragon $28.10
11/13/2003 914 Koni Competition Bump Rubber (70.34.95.000.0 FRONT, 2 ) Paragon $27.90
11/13/2003 914 Terry Clutch Cable Paragon $35.50
12/14/2003 trunk struts ebay $77.00
1/1/2004 914-4 Accelerator Cable, by Terrycable present $35.85
1/1/2004 914 Speedometer Cable present $33.00
1/10/2004 Ball Cup Shift Bushing at base of shift lever present $6.40
1/10/2004 Clutch Cable End, Metal Trunion, present $13.75
1/10/2004 Clutch Clevis Fork present $5.00
1/10/2004 Snap Retainer Clip / Pin For Clevis Fork (clutch cable to pedal shaft) present $2.50
1/10/2004 Clutch Cable Arm Bushing, 914 present $2.00
1/12/2004 steering wheel + adapter ebay $140.55
1/14/2004 mirror all914 $45.00
2/7/2004 Steering Shaft Bearing, 911/912E/911 Turbo (1974-89), 924/924 Turbo (1977-80), 914 (1972-76) pelican $19.25
2/7/2004 Lower Steering Shaft Ball Bearing, 911 (1974-89), 914/4 (1972-76), 914/6 (1970-71) pelican $16.50
2/19/2004 2 914-4 1970-76 Rear Caliper Rebuild Kits pelican $39.90
2/19/2004 2 1973-76 914-4 Front Caliper Rebuild Kits pelican $33.50
2/19/2004 Rear - Caliper Expanding Spring (sold per each, 2 required), 914-4 All pelican $10.70
2/19/2004 Caliper Rebuild Grease (Brand may vary) pelican $8.95
2/19/2004 Steering Rack Boot, 911 (1974-89) pelican $26.00
2/29/2004 2 914 Slotted Brake Rotors (FRONT, 411.407.075BSL, 914-4 73-76) Paragon $178.00
2/29/2004 Brake Lines, 914 All Stainless Steel, set of four; set of 4 (1972-76) pelican $54.50
2/29/2004 1970-76 914-4, 914-6 Ferodo Performance Front Brake Pads pelican $76.00
2/29/2004 1970-76 914-4 Ferodo Performance Rear Brake Pads pelican $76.00
3/1/2004 2 rear zimmerman rotors ebay $100.00
3/13/2004 Master Cylinder Cap Seal, 911/911 Turbo (1968-86), 914 All pelican $1.00
3/13/2004 2 Front Outer Wheel Bearing, 914-4 All pelican $10.50
3/13/2004 2 Front Wheel Seal, 914-4 All pelican $12.00
3/13/2004 2 Front Inner Wheel Bearing, 914-4 All pelican $12.00
3/13/2004 Master Cylinder Reservoir Cap 911/911 Turbo (1968-83) pelican $7.45
3/13/2004 Master Cylinder Reservoir Top Cover, 911 (1974-83) pelican $9.75
3/13/2004 Inner Door Seal, 1970-76 914 Right pelican $43.25
3/13/2004 914 Threshold Plate, Inner pelican $47.75
3/20/2004 Master Cylinder, 19mm, 911/912 (1968-76), 914-6 (1970-72), 914 19mm Upgrade. Comes with grommets for feed lines. pelican $129.75
3/20/2004 Master Cylinder Reservoir Grommet (sold per each, 2 req.), 911 (1968-76), 914 All pelican $6.50
3/20/2004 Adjustable Racing Rear Brake Proportioning Valve, 914 pelican $162.25
