914itis
Oct 2 2013, 10:11 AM
2.0 S pitstons, T cams, 40 IDA Webers, carrera tensioners.
does any of this add any performance to the engine?
d914
Oct 2 2013, 10:23 AM
Been a while since I played with 6's,,,
S pistons ,,, maybe a bit more compression
T cams ,,, not so much ,,, s cams fun...
Tensioner better for engine,,, performance no
40's ... Appropriate size for specs
Nice street engine if in good shape...
Cap'n Krusty
Oct 2 2013, 10:49 AM
S pistons produce a higher compression ratio, which T cams aren't meant to handle well. They work OK (just), though. Gives a better bottom end. You really need to know the valve and port configuration to determine what would be best.
The Cap'n
shuie
Oct 2 2013, 10:54 AM
T cams are not really an upgrade over any other cam. Unless you have no cams.
914itis
Oct 2 2013, 10:59 AM
QUOTE(Cap'n Krusty @ Oct 2 2013, 12:49 PM)
The Cap'n
That's all the info I have on my engine . PO says it was rebuilt with the info that've posted. Hats the only data he has. I just wanted to know what it means for the engine, thanks for the info
