QUOTE(914forme @ Oct 3 2013, 04:39 AM)
You should use two spark plugs as these look to be wasted spark coils. In reality they are like any other coil. Apply power and trigger them. Its just voltage, so it only hurts, amperage is what kills.
If you want to test the hall sensor, you can do that by hand and inject a signal through it, and wave a screwdriver in front of it. It will generate a pulse, you need an O-scope to see the pulses though.
I doubt you have an issue with the missing tooth wheel, unless its missing more
Only way I can see to test the logic section is hook it up
and run it in parallel on a running engine. ground the plugs and see what you get.
I have to protest here. Strongly. Milliamps kill, amps burn. Voltage in the 12 volt range have trouble generating much of any current in your body. Higher voltages will pass through, and stray millliamps going through the heart, as in chest, from the arm to ground can kill. So if you like getting zapped, ground your elbow to the car and knock yourself out. This is something like winning the lottery in reverse. Most of the time it won't happen, but that doesn't mean it can't.
Maybe you can tell I am doing my cardiovascular lectures this week and next.
