Having a great afternoon drive home from my shop with the top off. Then I start having issues getting into first gear. This is only the second drive since I put in a new clutch cable. First drive was the 914 Drive In / Pizza night in Newberg
Watch the video, the linkage gets bound up when I push in the clutch. Where did I get the cable and linkage goofed up? Cable adjustment? It moves back into center position when I let the clutch out. Hmmmm.
Could be your clutch tube weld up near the shifter has broken loose.
cary
Oct 6 2013, 08:37 PM
That was my first thought. We had that happen on the other car years ago. I seemed like it wouldn't open the clutch at all. Hmmmmm.
Almost time to put it to bed. I'll pull the carpets and run the camera in there and see whats up.
warpig
Oct 6 2013, 09:06 PM
I had a similar problem. Clutch cable was wrapped around the shifter rod the wrong way.
cary
Oct 6 2013, 09:13 PM
Where did it get wrapped around the shifter rod?
That's what the movement looks like. But for the life of me I can't figure it out where that would be. If I remember right, the clutch cable tube is well above the shifter.
KELTY360
Oct 6 2013, 09:23 PM
Could be wrapped around the accelerator cable.
cary
Oct 6 2013, 09:27 PM
Can the accelerator cable get wrapped around the linkage?
cary
Oct 6 2013, 09:41 PM
The plate on the tunnel gave us access for the tube repair we did years ago on the other car. Look how far ahead of the shifter the clutch tube attachment spot is. I still don't see where they would get tangled up.
It's got to be something simple ..................... Has to be cable related.
cary
Oct 6 2013, 09:53 PM
Just read this on a search.
I also remember one time that I had the clutch cable clevis threaded onto the clutch cable too far. This caused an interference between the two cables as the clevis couldn't pivot correctly.
cary
Oct 6 2013, 10:12 PM
Here's another picture .............. Look's like Rob is probably right. When you step on the pedal it would move under the linkage ......................
