Full Version: Help! eletrical issue I think.
914coop
I have 911 gauges with a getty dash. Issue is with the oil level/fuel level gauge. Hooked it up to the green wire from the sender and red wire with white stripe. Fuel level pegs when I turn on the ignition. Tried the 914 & another 911 gauge and they all peg. I have also tried another sender, with same result.
Need help with ideas on what to look for.
Thanks for any help.
Irv
904svo
Normally when it pegs you have a open in the sender lead to the gage
JStroud
Could also be a ground problem.
Jeff
