QUOTE(two-strokejohn @ Oct 8 2013, 09:36 PM)
I have a 1.7 with djet set up on a test stand. What is the minimum amount of wiring needed to run the engine. I know the coil needs power... also the fuel pump. what wiring etc is needed for the ecu to function. Any info would be appreciated.
Thanks, John
I tested my 1.7L with DJET by connecting +12V and Ground to the 4-pin connector on the DJET ECU. Also used the one output on the connector to power a relay to turn on/off the fuel pump.
And of course apply 12V to the coil.
