QUOTE(Razorbobsr @ Oct 11 2013, 02:09 PM)
QUOTE(TdiRacing @ Oct 11 2013, 01:21 PM)
I had an issue with the points closing up on my car with the msd on my 2.4L 6 conversion. I dont drive the car alot and this was an issue. Other issue maybe the rotor itself. They can burn the tiny wire inside. There is a how to on adding a thicker wire inside of rotor. I would check the points .
No points. Bob
That's good information. What type of points replacement module do you have (Compufire, Petronix, etc?) Do you have an original set of points, or a distributor with them that you could swap out?
As Rick said though, it would be easier to just wire it without the MSD first. Regardless of the pointsless module you have, the negative black wire should go to the negative side of the coil and red to the positive.
If it runs, then it's the MSD. If not, then it's most likely the points replacement module, which is very possible.
