Hey out there.....
I'm making big strides on my engine building! It's lots of fun!
But of course the questions continue.....
Attached picture should set the stage:
This much is obvious:
The oil cooler is mounted to the case via three long studs with washers and nuts. There are two oil seals that are sandwiched between the case and cooler.
The Haynes manual says "don't forget the washer between the case and the cooler". However, none of the exploded view diagrams show any washer there, only two on the outside with the nut.
Just as a check - my Bentley manual for my 73 VW Squareback shows 'spacers' set between the case and the cooler. They comment that the 'spacers' are essential.
Here's my question:
Are there supposed to be washers or spacers of some sort in between the case and the oil cooler? This is on my 1973 914 2.0.
I'll be back at it in the morning. Time to get some sleep.
Cheers,
Nate
