Paul at Performance Oriented is a Meistro.
Not sure how someone can tell your bushings are worn (Mark) without looking at them
What your describing are running issues that might be cause by shaft bushings but I'd make sure the items on performanceoriented.com are followed for tuning. It starts with a valve job. Then follow his lean best method to tune.
They probably need to be rebuilt. You can clean and get new gaskets in them yourself. If there are worn shaft issues you can see them as carbon traces on the butterflies when you turn them upside down. If you check out Paul's site you can see the amazing work he does. I spent a couple months with mine. Here's some recommendations:
1. Valve job
2. Get the proper syncrometer.
3. Rebuild the carbs
4. Find out everything you can about your jets and emulsion tubes.
5. Have the peak rpm of your cam on hand
6. Make sure you have the proper jets.
7. Make sure the emulsion tubes match the cams.
8. Make sure you have 3.5lbs of fuel pressure at the carbs.
9. Follow all Paul's tuning guidelines, especially the linkage adjustment procedure.
Even if the shafts are worn, that should get you running 100% better.
