QUOTE(914itis @ Oct 13 2013, 08:35 PM)
I got my six running, it's running a bit poor and cuts off . I am sure I need some adjustments.
I had about 1 gallons in the tank, I noticed that the filter had very little gas when cranking and the pump running. The pump is in the front. Am I getting enough pressure from the pump or do I need to bleed it and remove air.
How much fuel should be sitting in the filter?
First off, I would never fire up an engine (that's been sitting) in the car with less than a few gallons in the fuel tank. Beyond that, you'll see very little fuel in the filter at any given time while the car is running, but most filters suitable for use in a sixer are translucent and you can't see the fuel anyway. Pressure must be measured to be verified, as must volume. You don't bleed the fuel system on a carbureted engine.
The Cap'n
