QUOTE(rosenfe @ Oct 14 2013, 05:21 PM)
i m new to forum,looking at 72 ,seller says no rust,transmission rebuilt,car serviced regularly at local indy,has records for 3 years ,garaged.he doesnt drive much,not sure of true mileage.my question is how slow is 1.7,and what does it cost to upgrade to larger engine?do you need it?
Check the car out in person, or via lots of pictures.
See if he will remove the rocker covers and show you the longitudinals.
Rust and paint are the costly issues, everything is less money for restoration.
Motor, well a 1.7 can be loads of fun to drive.
Its not the weakest motor, the 1.8 is actually a bit less.
If you are buying the car with the expectations of it being super fast, budget at least 10k for an engine upgrade, depending upon what route you take.
Many motors fit and many upgrades exist
Big four rebuild
Porsche 6 transplant
Suby conversion
Chevy conversion
Etc etc
If you are seeking a conversion car in the long run, look at buying one that has all the hard work done already and needs to be finished or is all completed.
Rich
