I'm going to bet that they're talking about the kind of FI distributor on the CIS systems, you know like '82 Volvo's etc. Those had 4 hoses running to the injectors which were regulated by the mass air venturi plate & lever. Can't see how ignition distributor would be involved at all.....
r_towle
Oct 14 2013, 06:17 PM
You can use it but most people use the SVDA distributor from aircooled.net
wndsnd
Oct 14 2013, 06:49 PM
QUOTE(r_towle @ Oct 14 2013, 08:17 PM)
I don't want to invest on this. I have a complete Mallory Unilite, CD, and Coil system that I yanked out this morning because I stupidly shorted it out and I need to have the whole system checked. I think I cooked it as I melted the insulation of one of the CD box wires. Going old school to see if I can get it running.
r_towle
Oct 14 2013, 08:03 PM
It will work. Remember the bottom points and if you want use the vacuum port on the carbs joined at a T fitting to enable vacuum advance. You do not need vacuum advance.
Set it up with points and a condenser, set the timing at 27 degrees at 3500 rpms, to show you the full advance.
Rich
wndsnd
Oct 14 2013, 08:52 PM
Carbs do not have a vacuum take off that I can see. I was just going to leave the dizzy ports open.
rhodyguy
Oct 14 2013, 09:06 PM
you'll leave the vacuum advance portion on the table. a dist for the L-jet system will work.
