QUOTE(ndfrigi @ Oct 15 2013, 09:20 AM)
Just to chime in on this thread also. Can also someone help me finish mine, I already (with my neighbors help) prep everything and just need to weld it.
Please see attached picture. I also tried to ask some suggestions if I buy a Farmhand mig welder 125 on a separate thread.
With the way things look it would be wise to check the other two attachments in the tunnel.
Beyond that before you or someone else tries to weld, make everything shiny metal that will be within at least a half inch of the weld. You do that or learn the hard way. When the welder torch, TIG, or MIG hits rust it sets it on fire, making a blazing little explosion where you wanted a puddle of melted steel. That burning iron oxide blinds you even with the dark lens and burns holes in the surrounding metal. Also, while it is gassing off it isn't especially interested in forming a bond to anything. Just a disaster.
But, when you start with clean metal you think you are some sort of genius the first time out.
Best wishes. You may want to check out Restoration Designs if you haven't already. They have some nice weld in panels. I have a lot of them.
