Hello All.
A discovery in what not do do to your 914.
If you look closely at the last pix you will see the strip
of sticking plaster tape across the rear window.
In a misguided attempt at securing a tarp,a po
has that stuff,now aged,all over the bottom of the rollbar.
Time To Remove:4hrs.A pita totally unneeded as was
the removal of the "undercoating spray".
A few minutes handy work with a can made for a
marathon effort in a spacesuit.
Method.
1:spray "Gunk Brake Cleaner" on 6"x6" area of trunk.
2:before the rapid evaporation,wipe with papertowel.
3:Repeat 1>3.
TTR:22hrs.
The results made it all worth it somehow and I am
pleased to discover it was an attempt at preservation
rather than disguise.I heated then pulled the factory
sealer from the bottom corner to find real steel.
Click to view attachmentTaDa.
Much much more to do.>>
Click to view attachmentUnder the Infrared
Click to view attachmentA Fuzzy Photo
