QUOTE(jimkelly @ Oct 24 2013, 01:42 PM)
figure out how to orient the blocks and do you glue them to the body to keep them
in place?
Without a helper, I set the tank in the hole without blocks, then just lift the tank abit on one side and slide the block in. Same thing on the other side. Work back and forth and side to side to get it low enough and level. Orientation is simple. Each block has a slit, that goes on the seam of the tank. the other side has a point, that goes around the fender. test fit for RGT and LFT.
With a helper, you get one side they get the other....
Didn't think about glue, plus if the tank is like the rest of my car, I'll be pulling it out at least 2 more times before I get it right.
Hey, I don't see a "SOCK" for the outlet pipe. You will need one of those. And it does matter which hole is the outlet.
