Recently I swapped out my empi's for 4 bolt Fuchs. In the process I also switched from the "screw in lugs and bolts" to the proper long lug bolts for the Fuchs.
So now my setup is that i have to carefully balance my wheel on my toe while threading in the bolts.
My question is, what is the proper torque setting for these wheels and bolts because I just striped one of the holes in my front rotor. I think Hayes says like 100 lbs. The striping occured going to 90 lbs. Is this correct?
Secondly, should I be using an anti-seize lube?
btw, was able to tap the rotor so I think I saved it, but the long lug bolt is buggered.
thanks in advance
JR
