BahnBrenner914
Dec 21 2004, 04:02 PM
so i finally have my baby all sanded down and stripped to bare metal except for some nooks and crannies. and i must say, she looks good naked. but anyways, i was sanding in the grooves where the trunk rubber was that i pulled out and there is a lot of this rubbery glue crap in there that wont sand out or will take way to long. does anyone have an idea of how to remove this easily and/or quickly? thanks
aircooledboy
Dec 21 2004, 04:07 PM
3M makes a "Weatherstrip Adhesive Remover". Won't take off all types of adhesives, but will take off most quite nicely.
brant
Dec 21 2004, 04:25 PM
what about a mechanical means...
perhaps one of those wire wheel brushes?
brant
watsonrx13
Dec 21 2004, 06:55 PM
Aaron, I just recently stripped the rear trunk. I used Aircraft stripper to remove any glue and paint and used a wire-wheel to remove the seam-sealer.
Here's a shot of the trunk, you'll notice in the lower left corner the stripped channel...
Allan
Dec 21 2004, 07:05 PM
I was told that Acetone (If you have proper ventilation) will take off the adhesive. I bought some yesterday to try on the glue that was holding on the pad at the firewall in the engine compartment. We will see.
Aaron Cox
Dec 21 2004, 07:06 PM
how long did it take you to block sand her?
i need to do that soon...get ready for paint
BahnBrenner914
Dec 22 2004, 06:31 PM
i didnt sand it all the way down. we started sanding and scraping (thats how crappy the paint was) the top coat off and after 18 hours of sanding (2 guys with power sanders) we had a snowcamo looking unevenly painted POS. so i went out and bought chemical paint stripper. stuff will burn through anything. the paint just bubbles up and you scrape it off. serious stuff if you want to go down to bare metal.
and thanks for the suggestions guys.
