QUOTE(arcadeforever @ Oct 27 2013, 06:54 PM)
QUOTE(wilchek @ Oct 27 2013, 06:30 PM)
I have not run my 1.7 in two months. Whe I started it up fuel was coming out of the passenger front injector. I put it away and waited over night to work on to. When I looked at it today it was bone dry and did not leak at all even after 5 minutes of running. Not sure where it was leaking from, injector,seal, hose etc. any guess? The hoses seem to be ok. Do the seal in the injectors leak when dry. Seemed odd as it was leaking a lot. I am thinking replacing the injector,seals and hoses as when it leaks it drips on the header which seems ideal for a barbecue.
Where can I source a new yellow injector. It seems no one has them. I remember when the yellow were easy and the green where hard to find.
I have done that whole job on my bus and its a lot of work, but well worth it, I dont think id worry about replacing the actual injector, but, if everything is original, definitely replace the little hose between the top of the injector and the fuel rail and the seals ($5 at advanced auto), the crimped end comes off by destroying the fitting, cut a new piece of good FI hose the same length and get two new FI hose clamps (non worm type) and reattach them to the fuel rail, put the new seals on and you should be good to go..
Here is a link to the seals.
http://shop.advanceautoparts.com/webapp/wc...ection+seal+kitI shouldnt say its a LOT of work, its just about 3 hours by the time you pinch off the fuel supply, remove the fuel rails and replace the hoses and seals and put it all back together. I actually enjoyed it and you can sit back and not have to worry about your beautiful car going up in flames.
(I apologize for referring everything to "I did this on my bus" because I just got MY 914 yesterday and haven't even had time to tinker with it, my '75 VW Bus I have had for 4 years, and it has pretty much the identical setup)
