I have a '75 all done and ready to go when out of nowhere I lose the lights on the right side. Front and rear t.s., running lights. When the right turn signal is deployed the relay starts buzzing instead of clicking. Everything on the left of the car is fine, right headlight is fine. While troubleshooting this, all of the right side lights come back into play EXCPT for the t.s. running lights are now on, but same issues when I flip the stalk, relay starts buzzing. ALso no gauge lights or wipers ( which I assume is a different issue )
both reverse are fine
both headlights are fine, high and low
left side t.s. work as they should
I have tried 4 different relays, all of which I know to be good
2 different flasher switches
2 different headlight switches
Car is very clean, all grounds are in good order, I pulled all of the wiring from the front and rear light housings and all looks fine. Obviously this is related to something on the right bank but I am at a complete loss now.
Something in the stalks/column ?
