ChrisReale
May 25 2003, 05:06 PM
On D-Jet ther eis a stacked elbow that the dece valve line plugs into and the PCV hose plugs into. It is rubber, and I want to replace it with something more durable. I will eliminate the decel valve, so basically I need something that is a 90 degree angle, that fits into the phlenum and the PCV line can go into it. What have others used as a replacement for this piece?
Dave_Darling
May 25 2003, 06:01 PM
A short piece of hose, plus some brass plumbing fittings. The brass may be a bit heavy to hang off the side of the plenum, so you use a piece of hose so you can rest the brass on the engine block or something else in the area.
--DD
ChrisReale
May 25 2003, 06:07 PM
Sounds like a Home Depot trip. Thanks Dave
Bleyseng
May 25 2003, 06:19 PM
I heard Porsche is still selling those rubber 90's. AA also sells them. They wear out in about 20years so, maybe a new one would work too.
Geoff
