Root_Werks
Dec 22 2004, 03:37 PM
Ok, Joe posted what his 914 wieghed which really interests me now that I see his under the 2000lb mark. My 914-6 wieghs in at 2275 with 1/2 gas, glass bumpers, full int, 16x7&8 fuchs, heat, spare tire, tools in trunk, roller blades in rear trunk etc. Certainly not a stripped down car, nice driver.
So what do other scale in at? I wanna know!
URY914
Dec 22 2004, 03:40 PM
Root_Werks
Dec 22 2004, 03:44 PM
QUOTE (URY914 @ Dec 22 2004, 01:40 PM) |
Paul, I figured you would jump on this one!
machina
Dec 22 2004, 04:02 PM
This is my weight with me in the car, helmet, fuel, etc...
So I should be around 1900 dry. Since then I removed some stuff like the headlight motors and buckets but I added coolers, lots of ss oil/fuel lines, etc.
Car has full 8 pt cage, full metal bodywork and bumpers, all lexan windows, etc...
Root_Werks
Dec 22 2004, 04:06 PM
I like the pic, that is cool. Yeah, here is something I have wanted to try: Pull the headlight motors, use the struts like the GT's do, but with the cable, I was thinking about having something rigged up so you could push it, release the lights(up), pull it, moving the lights back down. Simple and save lots of wieght I would think. Plus driver friendly. I have some plans already, just have to try it out.
URY914
Dec 22 2004, 05:26 PM
QUOTE (synthesisdv @ Dec 22 2004, 02:02 PM) |
Car has full 8 pt cage, full metal bodywork and bumpers, all lexan windows, etc... |
Is that an X-ray of your car? Cool!
I don't know if mine would show up in an x-ray.
P
Andyrew
Dec 22 2004, 07:00 PM
Well... (thinks for a second)
More than yours
TimT
Dec 22 2004, 07:19 PM
Mine is about 2250 with my fat ass, half tank of fuel. interior is gone, full cage, 3.2....
sgomes
Dec 22 2004, 07:24 PM
Mine's juuuuuuusssst over 3000lbs
dlo914
Dec 22 2004, 07:41 PM
hmm at the local recycling center (Alhambra, Ca) there's an actual scale built into the ground to weigh a car before/after recyclable materials are removed....i should give it a try....before/after my scrawny
is out of the car
mskala
Dec 22 2004, 07:45 PM
I measured 2087 with about 1/4 tank and no spare. Also
I have no more tar. But done using digital bathroom scales
and levers, so any error will be multiplied. Anyway, I wasn't
concerned with the absolute numbers, just correct corner
weights. (corner weighted with my weight in driver's seat,
but I subtracted to get the 2087).
Eddie914
Dec 22 2004, 09:19 PM
2065lbs
- 3/4 tank of fuel
- 14 qts of oil with front cooler
- 2.7 with 40IDA3C Webers
- Roll bar
- 225/50/16 245/45/16 on 8"/9" BBS RA wheels
Still has:
- glass windows
- all interior tar mats
Eddie
Trekkor
Dec 22 2004, 09:32 PM
I had planned on wieghing in now and after the SIX shows up.
I'll drive over to the scales and find out Friday.
KT
ottox914
Dec 22 2004, 10:22 PM
2345 with spair, no jack/tools, full interior, all glass, 3/4 tank fuel, and 165# of me in the drivers seat. Also has the Brad Mayeur long repair kit, the extra heavy duty set, which I bet adds at least 50-75 to the total. Corner balanced to 49.7/50.3, but it took the spair and gas to get to those #'s. Oh, its a 1973 (heavy doors) 2.0.
How much weight would you loose by:
light weight battery?
headers+ supertrapp vs heat exchangers and bursch?
light weight gear drive starter?
no interior tar, no undercoating?
13 x 9 rims w/hoosiers?
early doors?
early interior?
(I think thats about all the DSP mods that could be made)
How would you best remove the tar/undercoating, short of "the dip" ?
David Parsons
siverson
Dec 23 2004, 12:16 AM
2189 lbs w/o driver
Pluses:
+ 3.6, 915, front mounted oil cooler
+ brad meyeur long kit + misc additional chassis bracing
+ steel GT flares, 16x8&9s
+ early steel chrome bumpers
+ passenger side mirror
Minuses:
- early 73 doors (no reinforcement [lighter], but late window mechanism)
- full, but minimal, lightweight leather interior (no tar or sound dampening of any kind)
- carbon fiber front and rear lids
Striping down the interior and going with lightweight lids can save a lot of weight...
-Steve
914Timo
Dec 23 2004, 01:33 AM
About 980 kg without driver. Thats about 2160 pounds. Full interior, 3.0 six, 901 and FG bumppers.
Joe Ricard
Dec 23 2004, 07:38 AM
Pretty interesting reading about the combinations of parts we have on our cars.
I like the easy cheap stuff, Floor tar (Gone), under coating (which still have) Dumping the stock heat exhangers, Thought about the super trapps
Engine sound pad gone and very heavy.
fiberglass bumpers getting weight off the ends is always good.
12 lb battery
Hmm Honey I need one of them lite weight starters
How much can you get off the trailing arms?
Been kicking around the idea of Lexan rear window.
AND I really want fiberglass trunk lids.
Deleting the head light motors would really help they are heavy. Pull cable and just spring up? I wouldn't mind stopping to put back down. Come on just design it I'll do it.
buck toenges
Dec 23 2004, 08:21 AM
Mine is 2200lbs with 1/2 tank of gas. 1971 chasis, 3.2, brad m longituds, steel flares, no spare, fuchs, full interior.
michel richard
Dec 23 2004, 09:21 AM
As per the scale at a nearby scrapyard, a couple of years ago: 2,150 lbs. With the 2.2 /6 engine, no driver, I believe the spare was in.
Michel Richard
Root_Werks
Dec 23 2004, 09:33 AM
Hi_Fi_Guy
Dec 23 2004, 10:36 AM
1920 Lbs.
2270 RAT
Fiberglass bumpers & decklids.
16x6 Fuchs
brant
Dec 23 2004, 12:24 PM
QUOTE (Eddie914 @ Dec 22 2004, 08:19 PM) |
2065lbs
- 3/4 tank of fuel - 14 qts of oil with front cooler - 2.7 with 40IDA3C Webers - Roll bar - 225/50/16 245/45/16 on 8"/9" BBS RA wheels
Still has: - glass windows - all interior tar mats
Eddie |
Eddie,
metal or glass flares? (I'm assuming some flare for those big wheels)
metal or glass hoods?
thank you sir
brant
Downunderman
Dec 23 2004, 12:32 PM
1034 kg with 3/4 tank. Full cage all trim F/G bumpers and spare.
232 234 45%
287 281 55%
brant
Dec 23 2004, 02:02 PM
I wish I knew what my new car weighed...
can't wait to finish it and find out if I achieved my "goals"
but I know what my old car weighed:
PCA production class "I" car
-all metal body, lights, heater, etc.
-full roll cage, all safety equiptment
-4cylinder
-enough interior to meet production class rules
-7inch cookies and vented rotors on front and rear
2141 lbs with 45lb ballast...
(minimum weight was 2139)
brant
balljoint
Dec 23 2004, 02:15 PM
At least $4500.00 so far, but it keeps adding up.
Root_Werks
Dec 23 2004, 02:33 PM
QUOTE (brant @ Dec 23 2004, 10:24 AM) |
QUOTE (Eddie914 @ Dec 22 2004, 08:19 PM) | 2065lbs
Eddie |
Eddie,
thank you sir brant |
If I remember corectly, Eddie has glass flares/removable even? I know glass lids, no headlights (still buckets sitting there though? and pretty stripped down int.
brant
Dec 23 2004, 02:36 PM
cool thanks dan...
now that you mentioned it I think he has answered the same question for me previously....
dang.. no memory left.. too much beeeeer.
brant
Root_Werks
Dec 23 2004, 02:37 PM
QUOTE (brant @ Dec 23 2004, 12:36 PM) |
cool thanks dan...
brant |
Burp What?
Joe Ricard
Dec 23 2004, 03:35 PM
SO, who still remembers what Balljoints avatar is from? Gosh that just kills me.
balljoint
Dec 23 2004, 03:37 PM
Uh oh.
I was wondering if you'd notice that. I haven't laughed that hard in a long time.
Marv's3.6six
Dec 24 2004, 10:45 AM
2040lbs 1/2 tank w/o driver, 3.2 w/ 915, fiber glass bumpers, fuel cell, 6X15 deep fuchs, 911S alloy calipers, drilled rotors, stripped interior, no radio, no heat, no carpet, no headlight motors. Wicked fast & loud, way fun.
Aaron Cox
Dec 24 2004, 10:46 AM
good to see ya here marv.....
love the blue on your car.....
brant
Dec 24 2004, 02:34 PM
QUOTE (Marv's3.2six @ Dec 24 2004, 09:45 AM) |
2040lbs 1/2 tank w/o driver, 3.2 w/ 915, fiber glass bumpers, fuel cell, 6X15 deep fuchs, 911S alloy calipers, drilled rotors, stripped interior, no radio, no heat, no carpet, no headlight motors. Wicked fast & loud, way fun. |
marv,
nice job... thats encouraging.
does your car have any window cranks/glass?
what about glass front and rear windshield/window?
metal or fiberglass hoods/lids?
good job
brant
brant
Dec 25 2004, 01:56 PM
aaron,
do you have any pictures of Marv's car?
what kind of set up...
bump...
brant
Aaron Cox
Dec 25 2004, 02:09 PM
QUOTE (brant @ Dec 25 2004, 12:56 PM) |
aaron,
do you have any pictures of Marv's car? what kind of set up...
bump...
brant |
i do.....
lemme find em...
Aaron Cox
Dec 25 2004, 02:10 PM
1....
From SoCal Funrun 1.0
Aaron Cox
again
Aaron Cox
Dec 25 2004, 02:11 PM
again again..../
soloracer
Dec 25 2004, 05:59 PM
I put my car on the scales at work and it weighed in at approximately 1400 lbs. It's a stripped tub with no interior, no engine, no transmission and no fuel tank. But it did have the following when it was weighed:
Sheridan Wide Body Kit
Kinesis 17" Rims w/315 & 285 rubber
Chassis/Control Arm stiffening kit
911 Front Suspension
Six Conversion Parts (bulkhead mount, oil tank, etc.)
Front Mount Oil Cooler
Pop ups w/motors, wipers w/motors, etc.
Partial Roll Cage
I'm hoping with the engine, transmission and Renegade Hybrids radiator that I can keep it under 2000 lbs.
