QUOTE(914itis @ Nov 7 2013, 01:41 AM)
thread hijack
Is there an advantage to use the air box? does it help with the carbs noise?
I mentioned this in another thread,the late great Bruce Anderson tested stock air cleaner vs k&ns,the k&n's dropped 1 hp over the factory one,he concluded in his tech notes it was a good design from Porsche
There are other reasons I wouldn't use them,would rather spent the money elsewhere,they do look pretty however.
Read an article on the bird about air cleaners some said steel some said plastic,appears there was a change around MY 70-71 for 911's,but no real set rule,besides many must have been changed over the years
My plastic one on my motor is flamed on one side (found out why),so I cut blocks of wood and jammed them inside and heated with a heatgun then chilled with water,its slowing coming right.
No question the steel one provides a better seal around the top of the carbs,this is very important.....anyone noticed how expensive these are getting now ,more 911 tax
