Andyrew
Nov 10 2013, 12:43 PM
So it appears that my high torque starter for my v8 has decided to bite the bullet.
I tried starting it on my birthday to get it running again and after quite a bit of cranking It I couldnt get it to start for one reason or another (Likely the carbs..)
At the end of the day it got to the point where the starter would barely crank (I had two batteries on it both on a charger.. Plenty of juice) and finally it would just click.
Now I've ruled out batteries and its been a couple of days and every day I would go out and check to see if it would crank and it wont. So its either the solenoid or the motor itself.
Anyone know if I can get this thing rebuilt or what my options are here? Its your typical ebay high torque starter, about 10 years old.
Mike Bellis
Nov 10 2013, 12:46 PM
Any motor car be re-wound. Is it worth it? my guess is about $100 to service it. There is a place in Hayward that can do it.
Andyrew
Nov 10 2013, 12:56 PM
Eh, I guess I could go for this one... 115 description says free shipping but ebay says $15.. I'll email him and tell him I want free shipping
http://www.ebay.com/itm/PORSCHE-911-MINI-S...0b4&vxp=mtr
Drums66
Nov 10 2013, 01:05 PM
....I'd weigh option of new vs rebuild!....proceed accordingly
McMark
Nov 10 2013, 01:25 PM
Are you running a solenoid/relay at the starter? I used to recommend against them, but lately I've changed my opinion. A solenoid/relay at the starter will save your ignition switch, which may be the culprit here. Get a 30A relay at your FLAPS - cheap test.
MartyYeoman
Nov 10 2013, 01:47 PM
QUOTE(McMark @ Nov 10 2013, 11:25 AM)
Running my starter thru a relay was one of the best upgrades I've done.
Marty
Drums66
Nov 10 2013, 02:13 PM
QUOTE(Marty Yeoman @ Nov 10 2013, 11:47 AM)
Marty
...Please explain this with a "high torque starter"????
Andyrew
Nov 10 2013, 05:27 PM
Im running an aftermarket key switch. Ignition switch died long ago.
I can hear the starter click to try, I know its the issue.
pcar916
Nov 10 2013, 09:36 PM
QUOTE(Drums66 @ Nov 10 2013, 02:13 PM)
It's geared
URY914
Nov 11 2013, 08:42 AM
I recently found a problem with my mini-starter. The threaded bolt that the hot lead lead bolts too is actually a threaded stud. Mine had backed out a few turns and was not making a good connection. Trightened up and it fired off.
DBCooper
Nov 11 2013, 09:22 AM
Take it apart, see if the main connections are good, as Ury suggests. If not fix them. Check continuity of the windings, if any of them are bad then recycle it, it's not cost effective to rewind Chinese electronics. From the symptoms I'd say that the constant cranking has gotten the brushes hot and they've fouled the commutator. Try lightly sanding the commutator, see if it needs new brushes, sand them too if there's still a lot of material left, and go from there.
Andyrew
Nov 17 2013, 11:31 PM
Found this..
If only I can find that small "L" brass piece to replace I think I can get this thing going again.
Anyone have any ideas on finding it?
Mike Bellis
Nov 18 2013, 08:27 PM
QUOTE(Andyrew @ Nov 17 2013, 09:31 PM)
Found this..
That "L" should be copper and is burnt! There's you problem, right there...
A starter rebuild shop might have something. Otherwise just make one. Looks easy if you can find the right thickness copper bar. You have the skills!
Or, just buy a new starter...
Andyrew
Nov 18 2013, 08:33 PM
^Ya I was going to give that a try this weekend. Im sure some place local can fix it up.
wndsrfr
Nov 18 2013, 09:24 PM
Try this outfit....
http://www.aspwholesale.com/index.php?act=...t&catId=223you'll need the make and numbers off of the starter.....it's prolly a Hitachi or Mitsuba I'm guessing......they have all the parts & you'll be much better off using new parts than trying to make 'em or jimmying with the burnt ones.
No affiliation....
