QUOTE(ressex @ Nov 12 2013, 10:42 AM)
QUOTE(gunny @ Nov 12 2013, 01:26 PM)
I use 87 octain as that is what the car was designed to run on. Save the money and add a wideband A/F mixture gage. You will then know if you need to adjust your MPS. I have a 76 with a calibrated MPS but was still running lean until I made the adjustments to richen it up.
Just my $.02
Hi - I'm glad this issue has come-up because I just bought a '76 2.0 with injection and pollution controls intact - found on 914world! I wasn't sure what to run and the previous owner had said 89 at most. I had assumed I should run higher and the little sticker in front says 91 but the octane rating were different then? Thanks.
Germany calculates using the RON (The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.)
The US (uses In most countries, including Australia and all of those in Europe[citation needed], the "headline" octane rating shown on the pump is the RON, but in Canada, the United States, Brazil, and some other countries, the headline number is the average of the RON and the MON, called the Anti-Knock Index (AKI, and often written on pumps as (R+M)/2). It may also sometimes be called the Pump Octane Number (PON).)
Because of the 8 to 10 point difference noted above, the octane rating shown in Canada and the United States is 4 to 5 points lower than the rating shown elsewhere in the world for the same fuel. This difference is known as the fuel's sensitivity,[4] and is not typically published for those countries that use the Anti-Knock Index labelling system.
So the 91 RON octane rating in Germany is about the same as 87 in the US.
RON x .95 =~US pump Octane.
