QUOTE(SirAndy @ Nov 12 2013, 03:10 PM)
QUOTE(1stworks @ Nov 12 2013, 12:33 PM)
Whats weird is it ran fine without ground in that plug for 7000 miles that ive had it?
No, that's not weird. It's just wrong and dangerous.
Without the FI brain controlling the ground your high pressure FI fuel pump will run continuously while the key is ON.
You car will run fine. It will also spray fuel all over your car just fine if you ever have a leak and it will also burn your car to the ground just fine if that leak is near a hot spot or spark.
It must have been controlling it bc i could hear the pump run than shut off.
There was never anything in the ground side.
Is it possible there's a ground spliced in somewhere?
Dont know till i find the fuel pump.Looks like its under the gas tank.
So i can run a small ground from plug to ground in engine compartment.
Whitch starts car and turn pump on and off property,or run 2 new wires power and ground directlyto pump......
Thanks again for help.
I dont want to start on fire.
