QUOTE(pba110 @ Nov 12 2013, 02:14 PM)
Hi,
Thanks for taking a look
I have a 1971 D Jet 1.7L 914. It has been running all summer after replacing the ignition points with an electronic ignition. The only other symptoms I've noticed are:
1. It seems to miss occasionally at 2900 rpm while cruising on the highway, if I accelerate the hesistation goes away.
2. The smell of gas while driving has been present for awhile, especially after filling up. Lately it has gotten stronger. My last two drives it became significant.
3. I noticed a fuel leak under under the car near the passenger's side door jam on start up recently that has not returned.
The car would always start on the 2nd or third crank and ran great otherwise.
Saturday it started only after cranking for awhile (i.e. a number of attempts over 10 minutes) and drove fine afterwards. The following morning (this past Sunday), it would not start.
I'm confused b/c once it starts it runs great.
I know the fuel leak needs to be addressed and will be but like most teeners, she is a driving project
thanks for any suggestions
1) Throttle position switch is dirty, there are threads here on how to fix/clean that.
It may have a worn groove, and its most commonly worn at the cruising speed....cause the switch has been wearing that area for 40 years...
Clean it with alcohol, and bend he tabs slightly to touch a whole new part of the board....re-calibrate it with an OHM meter...good for another 40 years.
There are also new board available from someone here...forgot who.
2) The fuel needs to maintain pressure for your starting issue.
You may have a fuel leak in the rubber hoses that are underneath the tank.
There is a skid plate under the steering rack...remove that.
Once removed, you can see a 4 inch hole right under the tank.
Get a small mirror and a flashlight...look at the lines.
The smell in the cabin could be from a leak under the tank.
It could also be an improperly connected Evap system....the charcoal tank on top of the gas tank needs to vent the fumes into the intake of the car...
There are two hoses running along the passenger side rocker cover into the engine bay...one is hooked up to the fan to blow air...the other is hooked up to the air cleaner to attempt to burn the fuel gases that happen from heat/cool etc.
If you have a fuel leak, the resident at rest fuel pressure wont be enough to easily start the car....so fix that first, then see if it starts better.
Rich
