DNHunt
Dec 24 2004, 06:17 PM
This little key is 5/8" X 3/16". I don't recall putting it in the new engine. Should I be worried?
914werke
Dec 24 2004, 06:27 PM
Dave ......
Isnt that the key for the fan Mount?
dgw
Dec 24 2004, 06:35 PM
Yeah, isn't that the key that locks the fan on the crank?
If that came out I would think you could move the fan pretty easily.
DNHunt
Dec 24 2004, 06:36 PM
Don't know but I hope not. It might be a little tough to do with the enging in.
Dave
914werke
Dec 24 2004, 06:45 PM
From Pet:
9, 901 102 147 00, WOODRUFF KEY, 1
914werke
Dec 24 2004, 06:47 PM
How do You capture the image out of PET?
Tryin to send post it for you Dave
boxstr
Dec 24 2004, 06:59 PM
Dave I would be very very worried, I don't think I could sleep at night. But then that is just me.
CCLINTHEKEYTOYOURHEART
skline
Dec 24 2004, 07:16 PM
It can be put back in with the engine installed, I have done it a lot. Just hope it didnt do any damage to the crankshaft. Dont run it without that in there.
Mark Henry
Dec 24 2004, 07:37 PM
STOP!!!\
Yep!! it's the fan hub key!
If you don't have one it will take out your crank!
Be safe and make sure.
Rocky
Dec 24 2004, 07:43 PM
Dave, I'm holdin one just as you described. What I can't understand is how it came out as you prolly installed the fan well ahead of the tin. It's like working blind but it can be installed in the car.
I took mine out today for shits and giggles on any and all curvy roads given the dry weather. You'll be glad you made the heat exchangers.
Happy holidays to all, Tim.
Rocky
Dec 24 2004, 07:46 PM
Damn Mark, I got wood lookin at all thoes heads on your avitar.
Tim
balthazar
Dec 24 2004, 08:19 PM
Um...I guess I'll ask the obvious (and betray my ignorance!!)
But, how does the fan hub key come flying out the front of the engine? Is it sloppy engine building? Does this happen to high mileage engines? How might I ensure that my current and future engines don't have this problem? Is this some sort of engineering/design flaw with the T4?
Happy Holidays Fellas!
Mueller
Dec 25 2004, 12:57 AM
QUOTE |
Um...I guess I'll ask the obvious (and betray my ignorance!!) But, how does the fan hub key come flying out the front of the engine? |
It cannot "fly" out...period...no way, no how !!!!
QUOTE |
Is it sloppy engine building? |
possibly just unlucky, when he installed the hub, it might have come loose, or it could still be installed correctly on the crank and this is an extra part from another project??? We won't know until he takes it apart, he needs to measure it 1st, if the dimensions are too far off, then i wouldn't worry about it, however if the dimensions match what belongs in the crank, then I'd be cussing
QUOTE |
Does this happen to high mileage engines? |
No
QUOTE |
How might I ensure that my current and future engines don't have this problem? |
Don't worry about right now with your current engine and when you rebuild your engine remember to install it....
QUOTE |
Is this some sort of engineering/design flaw with the T4? |
No, it is not, it might be a human error and that is all, the Type IV engine is a very robust engine
TC/914
Dec 25 2004, 02:08 AM
It might also be the WOODRUFF KEY that's used on the inner half of the alt. pulley.
Joe Bob
Dec 25 2004, 06:52 AM
With the indents on the edges....looks like a beat up/severed dime....
Joe Ricard
Dec 25 2004, 07:22 AM
Actually I would do it from underneath. Just take the front apron sheet metal off. You should be able to get at the fan hub while seeing what you are doing. Plus you get another chance to gawk at that beautifull motor from the under side one more time.
Good luck Any chance it came from the other crank when it was pulled apart? WAY LONG TIME AGO????
DNHunt
Dec 25 2004, 09:40 AM
Well I took the front apron off and then the fan and hub and I found a Woodruff key right where it was supposed to be in the crank. Guess I'll try the alternator next.
Dave
davep
Dec 25 2004, 10:36 AM
Unless the pulley came off of the alternator, there is no way for the key to get out. As you can see the key fits into a hole in the shaft. It cannot slide out. Then there is the washer and nut on the end it could not get past.
Rusty
Dec 25 2004, 10:39 AM
My guess is that it's an extra.
I've been finding extra parts in my engine compartment for years.
-Lawrence
Eddie Williams
Dec 25 2004, 10:41 AM
never say never
DNHunt
Dec 25 2004, 11:45 AM
I'll pull the alternator out this afternoon. I can't see how the key could be from there but, I've worked too hard on this not to spend an extra 45 minutes or so to find out. If it didn't come from there I guess I'll write it off to gremlins (same category as JP's magic smoke).
I raced a 1350 Merc for over a year with a nut and 2 washers left over after putting it back together. I never had a problem.
Dave
J P Stein
Dec 25 2004, 01:03 PM
Effin' gremblins. That's one of their tricks. Sneak into the shop and strategically place a gizmo (bearing half, piston circlip, O ring or 2,....woodruff key) in a spot where you'll be sure to notice it
.....and that's only when you're done doin' some motor work. A hungry 20lb barn cat will often keep them away.....but cat piss is hard on alloy wheels
I heared Wolverines work even better, but there are serious side effects.....
Joe Ricard
Dec 25 2004, 04:39 PM
See if you can get some of them attack Chichuhas
Or Maybe Rob Watson can loan you one of them Killer Dashounds.
Katmanken
Dec 25 2004, 04:58 PM
My gremblins hide stuff from me.......
I put it down, it's gone
I search all over and....... nuttin.
I move every thing and still can't locate it.....
Move the stuff back and it's still gone...
Ask others to look around for me (younger eyes) and... still nuttin
Give up in disgust.
Come back later
....and it's laying in the exact spot I thought put it down in: wacko:
This has been goin on all my life....
Think I need help...
Ken
DNHunt
Dec 25 2004, 06:30 PM
Well it wasn't any gremlins. It was the mechanics error (ME). TC914 you da man. It was the Woodruff key off the alternator shaft. DaveP don't worry it was my fault.
Here's what I found when I hauled the alternator out. No nut on the shaft.
DNHunt
Dec 25 2004, 06:38 PM
I found the nut under the car. And I found my large cresent wrench in front of the alternator on the front apron this morning when I pulled off the fan to check the fan hub. I thought that was kind of strange but it was early and I was tired so I didn't make a connection. So, how did this come to pass. Unless gremlins can lift large cresent wrenches, I suspect I left it on the alternator pulley nut. I was using it to turn the engine to find TDC and forgot about it. I think when I started the car it spun the nut off. DOH!
See no Woodruff key
DNHunt
Dec 25 2004, 06:40 PM
Pretty damn stupid mechanic. All better now, but, man I'm tired. Oh ya, it took a lot longer than the 45 minutes I thought it would. If I had to do this for a living I'd starve
Dave
J P Stein
Dec 25 2004, 10:41 PM
QUOTE (DNHunt @ Dec 25 2004, 04:38 PM) |
Unless gremlins can lift large cresent wrenches, I suspect I left it on the alternator pulley nut. |
This particular gremlin is named Dave
DNHunt
Dec 26 2004, 08:18 AM
One and the same.
Dave
balthazar
Dec 26 2004, 12:52 PM
Good job figuring out what the problem was! I learned a coupla things as well...That's what it's all about...
Eric_Shea
Dec 26 2004, 01:17 PM
The 20lb barn cat would definately keep the Gremlin's out of my garage...
I'm allergic to cats.
Sure glad you found this before serious damage.
Aaron Cox
Dec 26 2004, 01:39 PM
you sure it wasnt this gremlin?
Eric_Shea
Dec 26 2004, 01:42 PM
I could easily keep on of those Gremlins out of my garage "without" the help of a cat.
That being said... I'll bet those are starting to go for some money now
d7n7master
Dec 26 2004, 01:59 PM
Blame it on the KIDZ!!! Couldn't have been the BEER!!!
Aaron Cox
Dec 26 2004, 02:03 PM
QUOTE (d7n7master @ Dec 26 2004, 12:59 PM) |
Blame it on the KIDZ!!! |
thats what i do!!!
funny thing is....i got no kids.....maybe the gremlin got them too
davep
Dec 26 2004, 04:30 PM
Dave,
Did you find the big washer that goes under the nut on the alternator shaft? You will need that also.
Dave
Joe Ricard
Dec 26 2004, 06:08 PM
Well I have to admit I've been there done that too.
Well almost but just as funny.
Put a ratchet on the harmonic balancer of the Ranger. Don't recall what I was doing but left it on. Come time to start the engine and I heard this Really loud whizzing sound. Quickly shut it off and spent several beers trying to figure out what the hell that noise was. Not until I crawled up under the thing and nearly knocked myself silly did I figure it out... 1/2" Craftsman Ratchet going backwards at 1000 RPMS.
