Breaking news....
I just came across this 5 minutes ago.
I have been working on a OEM type Finnish for interior fiberglass parts for some time now. I was doing touch-up on a black gel coat dash and saw the targa top spatter pattern.
Polyester Gel coat cured in the mold will have a hard surface when pulled from the mold.
If I spray it on of a part it stays soft.
I have been using epoxy resin exclusively now for parts for quite a while. It just happened that I picked up some polyester resin this week. It has been so long since I have used polyester resin so I started asking some questions about the clear gel coats.
This is when I was told to spray PVA over the sprayed on gel coat to make it cure hard on top.
So on this touch up job I used a large tip on a top feed paint gun, little to no fan pattern. If I didn't spray too much for it to level out it had that spatter look.
I went ahead and sprayed more than I had planned just to test the texture look, topped it all with PVA.
I am thinking this could be perfected to be an exact match of the OEM top.
Still may have to thicken up the gel coat.
