Trekkor
Dec 24 2004, 11:50 PM
I've heard people here saying how hard it is to get the axles off or on.
Two words: air ratchet.
it's so simple. Just zip them dudes off or on.
I'll do it tomorrow. Or a least think about it a lot.
KT
EdwardBlume
Dec 25 2004, 12:14 AM
The stub from the tranny can be massaged with "LOVE" with an ordinary rubber mallot and a well placed tap....
Air rachet?
Brando
Dec 25 2004, 12:16 AM
best method on 4-bolt axles...
Trekkor
Dec 25 2004, 12:40 AM
I'm talking about the 8mm twelve point allen head bolts that hold the things on.
In that tight space, just pull the trigger and go.
I've heard people talking about vice grips and stuff...
KT
mightyohm
Dec 25 2004, 12:53 AM
It's not hard until you strip one of the bolts. Then out come the vice grips. Air ratchet won't help you there.... Also with a 3/4" extension you can easily get the ratchet away from the rubber boot and the job is a piece of cake. Just make sure the triple star bit is firmly seated into head of the bolt before you start turning.
Mueller
Dec 25 2004, 01:03 AM
QUOTE |
I've heard people here saying how hard it is to get the axles off or on. |
takes less than 5 minutes with standard hand tools, not sure what is hard about it???
careful with the air-tools, too much torque during the install and those bolts will snap...BTDT
skline
Dec 25 2004, 02:17 AM
QUOTE (trekkor @ Dec 24 2004, 09:50 PM) |
KT |
You mean there is another way??? That is how I always do it. So fast it takes like 3 minutes a side, if that.
iiibdsiil
Dec 25 2004, 06:30 PM
Air ratchets are for wussys, just use a 3/8 drive impact gun for removal. One tap on the button, it is out. Takes more frigin time to reposition on the other side than to pull the whole axle out.
