QUOTE(Cap'n Krusty @ Nov 16 2013, 06:54 PM)
QUOTE(gothspeed @ Nov 16 2013, 06:22 PM)
QUOTE(reharvey @ Nov 16 2013, 08:03 AM)
Used these when I was still running points in my cars because it kept any dirt or dust from under the cap from dropping onto the points. Ray
+1 ....... if mechanical points are used, then it should be kept in there ....
These covers are used in all late model Bosch distributors, IIRC. Keeps the crud out of the hall senders or the magnetic field coils. Using one is a no-brainer ..............
The Cap'n
Yes having a cover is best, however I have seen some electronic triggers that are too big and will not let the cover sit flush in there. The cover as you said is keep crud out, but more importantly 'conductive' metallic crud ..... which will affect mechanical contact points and cam the most.
A hall sensor/trigger is not as sensitive to 'crud' as it may seem ..... otherwise we would have to 'cover up' commonly used hall sensor crank triggers.
