QUOTE(Dr Evil @ Nov 17 2013, 10:07 AM)
91137504300 is a superior mount, less prone to cracking, and is cheaper. But, you would be using this as a transmission mount, not an engine mount unless you have one of the /6 mounts that use this. Depending on rear or side shift trans, you will either have rubber from engine to mount bar, or these up front at well (tail shift). The mount holes are often not perfect, but a little filing and they are fine.
Good to hear a selection from the Dr. himself! ........ I bought those hard urethane ones with the steel top plate and they were too rigid for my taste ...... I will get these 'superior' versions when I begin assembling my 1973 ......
