Greetings. I'm a new poster and a long time lurker. Thanks to all the amazing folks who post, I can always find an answer using the search function. I'm rebuilding a GA case 2.0 I pulled out a wrecked (bent) 914 I got cheap. The motor is interesting, has low compression bus pistons, real 3 bolt 914 heads that appear rebuilt, a hydraulic cam and lifters.
I've had the crank tuned .25 under and I'm beginning to pull together parts to reassemble. I'm keeping the stock FI, increasing cylinder size to 96mm and using Jake Raby's 9590 (new version of the 9550) kit.
I have two crank gears, one I bought:
and one that was on the crank in the motor:
My questions is that on one of the gears the alignment marks are exactly opposite the key slot, on the other the alignment marks are one tooth to the right.
Is one or the other correct? Tom Wilsons book seems to indicate that the alignment should be opposite of the key slot.
Any help much appreciated!
