Daiberl
Nov 18 2013, 09:26 AM
I could get a 3.6 from a 964 to replace the 2.2E I have in the -6 at the moment. I would run the 3.6 with carbs, currently I have a MFI on the 2.2. What would I need besides long block, plus the fan/alternator/shroud and distributor? Would all the other stuff like heat exchanges fit, could it easily be returned to the original engine? What size carbs?
- Juergen
brant
Nov 18 2013, 09:36 AM
You need a front cooler
ConeDodger
Nov 18 2013, 09:59 AM
QUOTE(brant @ Nov 18 2013, 07:36 AM)
The 3.6 doesn't have an on engine cooler so you need a cooler up front. None of that cheesy under the trunk shizit is going to work when you make that much heat. Check into what SirAndy did with his as he deals with a lot more heat than you will.
Why not run it with its EFI? Trying to stay with the original look?
Daiberl
Nov 18 2013, 10:13 AM
QUOTE(ConeDodger @ Nov 18 2013, 07:59 AM)
I have a front oil cooler but it's a small one and it's in the front but not the one in the trunk so I would have to get a new one. If I would go with a 3.0 would the big oil cooler be needed?
0396
Nov 18 2013, 10:17 AM
Like others have said, 3.6 does not come with a cooler ...in place is an oil filter. If your going to rebuild it, you can have machine shop make the necessary mod to accept the usual cooler that's usually there. Good luck..I'm heading down the same path.
billh1963
Nov 18 2013, 10:31 AM
You will also need $$
If it's an early 964 and the engine has not been resealed now would be the time
ChrisFoley
Nov 18 2013, 11:26 AM
QUOTE(brant @ Nov 18 2013, 10:36 AM)
Not really.
A pair of Setrab dual fan pack mufflers mounted under the rear trunk is sufficient.
Jgilliam914
Nov 18 2013, 02:17 PM
QUOTE(Racer Chris @ Nov 18 2013, 11:26 AM)
Not really.
This is what Rich Johnson told me as well
Daiberl
Nov 18 2013, 02:18 PM
I don't plan to rebuild, the engine has 65,000 Miles and runs strong. If I would go with a Setrab dual fan pack and I don't plan on tracking the car (ok, maybe once or twice) can it be done without any irreversible modifications?
- Juergen
Nov 18 2013, 02:53 PM
QUOTE(Jgilliam914 @ Nov 18 2013, 12:17 PM)
Not really.
For daily driving, i have to block off most of my front mounted cooler to even get the motor up to operating temp.
It's not even that cold here in mid-cal yet and i can't get the temps over 180 (which is where my thermostat opens). That is with 2/3 of the cooler already blocked off.
I'm actually thinking about blocking it off completely for the winter months.
http://www.914world.com/bbs2/index.php?showtopic=211602
pcar916
Nov 18 2013, 02:58 PM
Not really.
We know what you meant. What size are the coolers to replace the Behr, and where are you getting the cool air from?
My front trunk cooler is shown below and is mostly enough. I also use an auxilliary cooler from a sandwich adapter at the engine filter for hot summer days at stoplights, and steamy track days. It's a summer thing, but no fans needed.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
bcheney
Nov 18 2013, 04:25 PM
You can contact Patrick Motorsports out in Phoenix Arizona. They can provide everything you would need. Quality stuff at moderate prices. They have done a ton of 3.6 914 conversions and have many off the shelf parts they can get to you quickly. Good guys to talk to. I did a 2.2 conversion and they help me with an engine wiring harness that was beautifull and a hard oil line and aeroquip lines and fittings.
http://www.patrickmotorsports.com/packages/
East coaster
Nov 19 2013, 06:07 AM
Modified engine tin, heat exchangers are likely too small a diameter tube for the 3.6, different flywheel, sooner or later a beefier trans and axles.
ChrisFoley
Nov 19 2013, 08:13 AM
QUOTE(Daiberl @ Nov 18 2013, 03:18 PM)
- Juergen
A few bolt holes here and there is all the modifications needed.
The first pic was taken before the heat shield was installed.
0396
Nov 19 2013, 08:30 AM
QUOTE(Racer Chris @ Nov 19 2013, 06:13 AM)
- Juergen
Sweet looking set up
JmuRiz
Nov 19 2013, 08:58 AM
Very fancy, that's like the setup Patrick did on a 3.6 skinny fender 914 in Excellence many moons ago.
ClayPerrine
Nov 19 2013, 09:44 AM
QUOTE(Racer Chris @ Nov 19 2013, 08:13 AM)
- Juergen
What are the dimensions of the coolers?
Daiberl
Nov 19 2013, 07:07 PM
QUOTE(East coaster @ Nov 19 2013, 04:07 AM)
So you are saying that I have to get different heat exchangers as well as modifying the engine tin? What has to be modified and if I would run the original heat exchanger, would it work and if yes how much power would I loose because of the smaller diameter?
Nov 19 2013, 07:14 PM
QUOTE(Daiberl @ Nov 19 2013, 05:07 PM)
Yes and yes ...
Straight from my conversion thread:
http://www.914world.com/bbs2/index.php?showtopic=44700
Daiberl
Nov 19 2013, 07:31 PM
QUOTE(SirAndy @ Nov 19 2013, 05:14 PM)
Yes and yes ...
Wer lesen und suchen kann ist klar im Vorteil, danke
Ok, then I think I will pass on a 3.6, I would like to keep the car as original as possible and here in the PNW I need heat.
brant
Nov 19 2013, 08:08 PM
you still need bigger diameter headers for high flow or big displacement
I run larger diameter on a 2.0 for race purposes.....
you can buy billy boat or aftermarket heat exchangers that are bolt on.
