QUOTE(7TPorsh @ Nov 18 2013, 01:54 PM)
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter?
I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch?
I added a starter button on my dash , but I also put a relay under the dash ,it's wired
to the ignition key ,so that it only works when the key is on , I got to test it this
weekend at the ramble , & I liked it , mostly because if I stalled the car I Did Not
have to turn the key all the way back to the off postion and back to the starting
postion , I just push the button , it's quicker
, and it only works when the key is on , Bill D.
i's a 40 amp relay , fuse wired to hot wire under the dash , plus grounded , I spliced into the
yellow starter wire after the ignition key ,also spliced the black wire to the relay (hot key on / cold key off ) turns relay on , less stress on key switch ,
