I just picked up a '72 914 with the stock 1.7 FI engine a couple weeks ago. It's been a blast to drive and it was doing great until a few days ago.
But now it will not start after it's been driven more than a few minutes unless you let it sit for a significant amount of time, usually overnight. The engine cranks, but doesn't fire once it's warm and even within a couple hours after it's been driven. Starting completely cold for the first time each day doesn't seem to be a problem though.
It's also starting leaking a significant amount of fluid. I can see drip marks all along the underside of the engine, the oil cooler, and on the oil filter, but everywhere else is bone dry. The fluid on the ground looks and smells like gas mixed with oil. However there's no leaks from anywhere I can see in the fuel system.
I'm a type1 guy used to carbs, this is my first type4, so I'm not particularly familiar with what can go wrong with the FI system. Could it be leaking gas into the oil somewhere?
I'm guessing the two issues are related since they began at the same time. Does anyone have any idea what's going on?
Thanks!
