neo914-6
Dec 25 2004, 10:35 PM
I think I know where most of these go but not sure where the washer goes.
I already replaced the one on the fuel inlet. How about the shiny plug?
SLITS
Dec 25 2004, 10:38 PM
Would have loved to have lied to you, but the pic doesn't show for me.
Edit...it finally showed...what kinda carb. Top two look like a needle and seat assy, gasket looks like it for a power valve and the shiny plug, well it plugs the shiny hole (no idea unles it is threaded).
neo914-6
Dec 25 2004, 10:40 PM
Also need to know if I could get away with not installing the spacer. I think I put it in originally because I didn't think the manifold flange would seal. What do you think/know?
neo914-6
Dec 25 2004, 10:42 PM
Bottom of the carb...see the triangular cavities next to the chambers?
SLITS
Dec 25 2004, 10:43 PM
should work....looks like you have a square bore manifold and if you have a square bore carb, it will work.
SLITS
Dec 25 2004, 10:45 PM
Id that an Edelbrock (Carter AFB)?
neo914-6
Dec 25 2004, 10:47 PM
Carter AFB, Edelbrock bought Carter?
Thanks, now maybe my lid will fit!
Felix
SLITS
Dec 25 2004, 10:50 PM
QUOTE (Jaiderenegadesimpson V8 914 @ Dec 25 2004, 09:47 PM) |
Carter AFB, Edelbrock bought Carter? Thanks! |
Edelbrock makes a copy of the Carter AFB called the Preformer. They are, as I remember, dead the same.
Andyrew
Dec 25 2004, 11:04 PM
stock manifold? Eeek gawds!!! loose some weight and get an aluminum!!!!
skline
Dec 26 2004, 12:09 AM
Extra parts are never good, didnt it come with instructions? I agree though, lose the cast iron manifold and go with a Performer, you will notice an increase in performance too besides the weight factor.
neo914-6
Dec 26 2004, 12:22 AM
QUOTE |
stock manifold? Eeek gawds!!! loose some weight and get an aluminum!!!! |
I got one but it's for my custom built 358 cid engine. Dyno tuned 402hp, Compression 10:1, Ross Racing Pistons, Eagle H Beam connecting rods – 6 inch, Edelbrock Aluminum Heads – 2.02 – 1.60, Forged crankshaft, Milodon gear drive, Edelbrock Cam Hydraulic Flat Tappet, 1.5 Aluminum Roller Rockers, High Volume oil pump, Edelbrock Performer aluminum intake manifold, Corvette competition headers...
Just taking car of the carb first...
QUOTE |
didnt it come with instructions? |
Yeah but the font is ~4pt and the exploded drawing is just as small.
Thanks,
Felix
DJsRepS
Dec 26 2004, 07:49 AM
That spacer is not a spacer it is an adaptor to get the bores of a larger carb to mate up to the holes of an smaller intake, or even vice versa. The smartest way to do away with that adaptor is mate the carb with a large bore alum intake.
Maltese Falcon
Dec 26 2004, 09:13 PM
Hey Felix, I'm running almost the same set-up on my '85 VW dualcab, except with Holley Projection. It sets up w/o any software and throttle response is real crisp...I like it way more than any 4bbl I've tried. It also offers any variation of cold/ hot, accel/decel , lean/rich tuning you can throw at it ...all done manually at the ecu. ALSO if you're using the cam gear drive with the quick change cam housing cover: make sure that the o-ring seal is fresh. I used my NEW one in the kit , but it was dry and now sweats out of the cover
I'm using a big hydraulic Isky cam and making about 400hp out of a 357", it breaks sway-away axles with ease !
neo914-6
Dec 26 2004, 11:26 PM
Martin,
I really wanted the Holley Projection but I hear good and bad things about it. Probably depends how well it's installed but it seems to simplify tuning. The V8 owner I bought the motor from swears by Edelbrock Commander EFI. That van sounds awesome, how about posting some pics. I plan to install the 357 now because I think I talked a potential buyer out of buying it with the 283. At least have fun with it for awhile until I get my new car back in Feb.
Happy Holidays!
Felix
Maltese Falcon
Dec 27 2004, 11:27 PM
Felix, I need to hook up the output/input between my scanner and PC. It's never worked and my nephew who installed my new Dell system now tells me that it needs to be completed . For now my 5.7 Dualcab is at my www.msdsinc.com site in Project Vehicles
I do like the Holley Projection for its simplicity, I only added in a fuel pump kill for easier hot re-starts. Seems that on hot starts it will just keep dumping in fuel when you don't need it
Marty
PatW
Dec 28 2004, 12:08 AM
QUOTE (Jaiderenegadesimpson V8 914 @ Dec 25 2004, 08:40 PM) |
Also need to know if I could get away with not installing the spacer. I think I put it in originally because I didn't think the manifold flange would seal. What do you think/know? |
That spacer looks really mickey-mouse. Can't tell for sure if that manifold is a spreadbore?. If so, might run better with a small cfm vac-secondary spreadbore. IMHO
Pat
Rgreen914
Dec 28 2004, 02:41 AM
If you look at the pic of the carb/throttle bores, outside the primaries (lower right in pic), there seems to be an aluminum plug of about equal size which is visible. Correct carb spacer also serves as insulator to keep engine heat from percolating gas out of carb/help cool air-fuel mixture. Small Holley would simplify rebuilding/tuning chores immensely. Once saw a Navy officer in Long Beach driving Pantera with tunnel ram and dual Hollies; radical look on a mid-engined car (probably over-kill for teener, but would look outrageous)
Ron
neo914-6
Jan 7 2005, 01:04 PM
Martin,
Are you using 900cfm? The 700 cfm is only good for 275hp.
Felix
