shawn914
Nov 21 2013, 10:09 PM
Need to remove these wheel studs. I've tried a C-clamp, without success. Thought about a BFH but that can't be right (right?). Any ideas welcome - thanks.
Thanks
Shawn
(I did a search with the google app, no threads located)
Mike Bellis
Nov 21 2013, 10:16 PM
20 ton press...
Elliot Cannon
Nov 21 2013, 10:22 PM
QUOTE(Mike Bellis @ Nov 21 2013, 08:16 PM)
20 ton press...
Or a BFH. I used one and it worked great.
Spoke
Nov 21 2013, 10:23 PM
QUOTE(Mike Bellis @ Nov 21 2013, 11:16 PM)
20 ton press...
Your local automotive machine shop or repair station with a press can do it. I had rear hubs re-studded for $30.
messix
Nov 21 2013, 10:29 PM
u gotta compressor and a air chisel ?
use the drift point and air hammer it out, works on my one ton rotors.
Montreal914
Nov 21 2013, 10:36 PM
Just did mine with the press yesterday, piece of cake.
Now the hubs are at the anodizer for refinishing, looking forward to see the result...
914dave
Nov 22 2013, 05:03 AM
Shawn
I have a 12 ton press if you want to bring them up and we can press them out.
Dave
jimkelly
Nov 22 2013, 05:18 AM
shawn914
Nov 22 2013, 05:27 AM
All - Thanks for the suggestions, I don't have a compressor (yet...) so good to know a BFH can do the J - O - B. However the offer of a press is mucho appreciated - thanks for the offer Dave! PM sent.
Jim - great thread, thanks - bookmarked.
Shawn
shuie
Nov 22 2013, 08:30 AM
The fronts can be pressed out pretty easily in a bench vice. Unless the rears are welded in, you should be able to put a steel lug nut on them and whack them out with a hammer.
Rleog
Nov 22 2013, 08:52 AM
Here's a link showing a tool available at Harbor Freight that can be used to press out studs:
http://forums.evolutionm.net/evo-tires-whe...-safe-easy.html
Krieger
Nov 22 2013, 09:41 AM
You could try heating them in an oven for a while then hitting them. 200* would be safe
