SOLD 12/24, received funds and shipped 12/31
I ran across these SSI stainless steel heat exchangers in a box up in the loft today, forgot I even had them
Solid head pipes and bright shinny sheet metal. The passenger side has a few very minor dings top-side, and the bottoms (the part you actually see) are flawless (see pix). No rips or tears to the heater tube mounting holes.
Someone re-welded the tabs on two of the head pipes and didn't bother to grind down the slag, so it looks a bit, uh - ugly. But wait ! ... a mere 10 minutes with a grinder and these welds will look just fine.
I spent a little time cleaning one of them up, but if you're desirous to have the nicest HEs in town, you could spend another 20 minutes with a wire wheel on the pipes and some scotch-brite on the sheet metal. Then, these HEs will absolutely astound your neighbors, family and friends
This would be a perfect winter project for anyone eager to join the the ranks of the rest of us cool guys who run with SSI HEs ...
$350.00 shipped (insured) via FedEx anywhere in the CONUS
Provide me with a business address that will accept the shipment for faster delivery
