QUOTE(pcar916 @ Nov 29 2013, 07:15 AM)
I considered using the one from my '84 Carrera (parting out) but the ATE 23mm master cylinder is almost too long as it is, and I didn't want to take the chance. Someone with both will know for sure.
I'll admit the aluminum piece looks better... for something I never look at. Don't know the weight difference. Anybody weigh them recently enough to remember?
You will need the aluminum cross member to clear the 23 mm master cylinder if it's the Mercedes style this I know for sure. I ran this setup in my 71 914 years ago. I have both a 23 mm Mercedes and 23 mm master that automotion sells. I can take some measurements of each if needed. I've seen the steel cross member used/modified by putting a nice dent in it to clear the master cylinder. I chose not to do this and went with the aluminum cross member. If you go with the 911 a-arms check to see if they are the late (under car) or early (through body) sway bar style. Either one can be used in a 914 but if you use the late style you will need the sway bar as well. I got a set of late style a-arms and cut the sway bar mounts off. I ended up welding on the U tabs to use a through chassis sway bar.
