Is there a knack to fitting the seal that run's along the the top of the windshield and down the pillars on my 1970 914.Not sure if you start at one side then along the top then down the other side,or side's first then the top. Thanks
gothspeed
Nov 29 2013, 01:59 PM
QUOTE(cal914 @ Nov 29 2013, 11:46 AM)
I think you do the two sides first, then fit the top after the sides are all the way down. At least that is the way I did it on mine.
cal914
Nov 29 2013, 02:11 PM
Does the seal finish at the bottom of the trim,also do you screw the seal in the top corner's .If some body could put a picture yp of where it finish's and where the screw's go that would be very helpful Thanks
