Full Version: Which Distributor?????????
Teknon
Which distributor would be best for a dual 44mm Weber, 96mm x 78mm engine??? IPB Image
scotty914
if you are staying stock a 1.8 dizzy, iirc its a 205 a
Teknon
It's bored and strocked with dual 44mm carbs and a larger cam.
scotty914
sorry i ment stock ing, not going mallory or something along those lines, the 1.8 dizzy will work with crane and other ones but i dont know enough about mallory to point you that way
Aaron Cox
for modified engines.... Aircooled.net recommends the mallory with the grey/grey springs. fully adjustable
