QUOTE(ndfrigi @ Dec 4 2013, 08:20 PM)
QUOTE(ThePaintedMan @ Dec 4 2013, 05:36 PM)
POR-15 is really finicky. Eastwood makes a rust encapsulator which is apparently much easier to use and what I'll use in the future if I ever need to again.
POR works great on areas that have some surface rust and "tooth" to them already. It sucks on any smooth metal, and even when I prepped my areas exactly as described, I got a ton of fisheye. I've painted multiple cars and never got a single fisheye, so why POR is the way it is, I do not know.
+1 on wearing a longsleeve shirt, pants and two sets of gloves. You will not get the stuff off once it's on you.
Do you think sir I should just use Eastwood Rust Encapsulator instead of POR-15 which need more preparation compare to rust encapsulator?
thank you again!
Whoa.....
There are several different products you are talking about.
POR has a rust encapsulating paint. For light surface rust you should just apply it given you have selected the right product. Talk to them directly....they are right by you in OC....nice folks.
A rust conversion paint coverts the surface oxidation into a hard oxide coating....sort of like anodizing aluminum....I won't get into the metallurgy part. When using a conversion paint you should just make sure the surface is free of dirt and grease. On new metal you will need to actually make it rust...to make it work. So if you are using an conversion paint...don't waste your time taking it down to bare metal.
Call them.
I agree with the other comments on heavier rust on structural components....they should be repaired.
