nynone4
Dec 28 2004, 02:18 PM
I'm replacing the stock front sway bar on the six, and was wondering:
Is there a trick to removing the outer triangular plate and corresponding rubber bushing to get the original bar out of the car? It seems like the rubber bushing will not slide over the square end pieces of the bar without the proper combination of swear words. Anyone know the combination?
The car is freshly painted, so I've been a little hesitant to get too "enthusiastic" with removing it yet.
Thanks in advance for any help!
JeffBowlsby
Dec 28 2004, 02:52 PM
Slice it to get it over the bar.
davep
Dec 28 2004, 03:21 PM
I'm with Jeff on this. The covers are bolted onto the body. In fact, the inner nut plates are supposed to be welded to the body with four holes cut in the body for the bolts and swaybar to go through. I thought the rubber bushings were split to begin with. Factory ones are I'm pretty sure.
One removes the 3 bolts, then pops the cover off of the bushing, and finally splits the bushing to remove it from the bar.
nynone4
Dec 28 2004, 04:11 PM
So you're saying the triangular metal plate (the one in the fenderwell - not the threaded part) should seperate from the rubber bushing fairly easily? Mine feel like they've become bonded together. I'm real close to torching the old rubber out. Not the method I'd prefer - but I suppose it will work.
datapace
Dec 28 2004, 04:36 PM
Did this this weekend to install a tarett bar.
I tried for about 15 minutes before I gave up and used a MAPP torch. Same deal as with the a-arm bushings, look for whispy smoke then turn and twist off. It took about 10 seconds to remove. Obviously, you only need to do one side nthen slide the bar out the other side with the drop link attached.
Doing this kills the bushing, which probably needed replacing anyway.
-bryan
Eric_Shea
Dec 28 2004, 06:10 PM
Over the years they become one (well... almost). The best method is described above. Just a whisp of smoke, no need to choke yourself out of the garage.
Factory bushings are not split. A box cutter can accomplish the task and make removal that much easier. If it's too hard you may want to carefully cut away with a cut off wheel.
Mueller
Dec 28 2004, 06:24 PM
it seems like one should be able to "drive" the bar out with a suitable drift
unbolt one side and from the other side, push the bar thru the mount still on the car.....it shouldn't take that much force or damage anything....lube the bar on the end you are hitting to help the bar squeeze thru....
RustyWa
Dec 28 2004, 06:43 PM
I'm going to quickly hi-jack this thread, but it follows along. I've got new bushings for a stock bar. The new bushings are not split. Should I split them? They are almost as hard as rock and it's hard for me to imagine them sliding over the square end of the bar.
jim912928
Dec 28 2004, 06:46 PM
Yes...you split them. I just added a front sway bar to mine and it is the only way to get it on. The cup that goes over it will compress it and keep it in place. Use some type of lubricant with glycerine on the inside so the sway bar can move in it easily.
nynone4
Dec 28 2004, 09:09 PM
Thanks for all the help guys!
Eric_Shea
Dec 28 2004, 09:32 PM
Yup... those hard ones need to be split.
maf914
Dec 29 2004, 08:12 AM
QUOTE (Eric_Shea @ Dec 28 2004, 07:32 PM) |
Yup... those hard ones need to be split. |
Do the aftermarket delrin or poly swaybar bushings squeek,creak or groan after installed?
On my Nissan pickup I installed a set of fat ADDCO swaybars with red poly-urethane bushings. They work great and really reduce body roll. After a while they started creaking when the suspension compressed over bumps. Really annoying. I tried something I had read in the Road & Track Q & A column. I removed the bushings, which were split type blocks and wrapped the sway bars at the bearing points with teflon thread tape. Just a few overlapping wraps. Put it back together and no noise. This was years ago. Just a suggestion if the bars make noise.
nynone4
Dec 30 2004, 09:01 AM
QUOTE (datapace @ Dec 28 2004, 02:36 PM) |
I tried for about 15 minutes before I gave up and used a MAPP torch. Same deal as with the a-arm bushings, look for whispy smoke then turn and twist off. It took about 10 seconds to remove. Obviously, you only need to do one side nthen slide the bar out the other side with the drop link attached. |
Using a little heat worked like a charm - and the new bar went on very easily. Thanks again guys!
Eric_Shea
Dec 30 2004, 09:04 AM
QUOTE |
Do the aftermarket delrin or poly swaybar bushings squeek,creak or groan after installed? |
Yup they do...
Good idea!
I wonder how long that stuff stays on there? Sounds like you've got at least a couple years under your belt with yours.
