QUOTE(Mike Bellis @ Dec 5 2013, 07:47 PM)
GM sensor is 0-90 ohm.
Stock 914 VDO sensor is 70-0 ohm. really only down to around 3-7 ohms, then drops to zero.
First off your level will read full when empty and vise versa. It also will be off and out of calibration.
A Chrysler sender is 10-70 ohms and will be the closest in calibration. But still backwards. I had one and was able to flip the resistive element and make it work correctly, although slightly off in calibration.
Thanks for the clarification Mike! That makes it easier to decide what I have to do...
