To the brain trust that is every present.
I just finished assembling my first ever type 4 engines.
After reviewing the remanding gaskets- I have an o-ring that I have no idea where it goes. The only thing that measure close to the size is an oil pump gasket …I used another new oil pump that did not require the gasket shown. So … where does this mystery o-ring go??
Measures the same size as the crank –pressed in seal .
Thanks in advance for your comments.
